Proof with even numbers and divison
gmmstr827
Prove that the product of two even integers is divisible by four.
If a·b where (a^b)ЄZ+, then 4|(a·b)
If 2|a ^ 2|b, then (a^b)≥2 v (a·b)=0
If 2|(2·n) then 4|[2·(2·n)] for nЄZ
∴ 4|(a·b) where (a^b)ЄZ+
[X]Is my proof correct? Is my notation for a positive integer correct (Z+), or should I not use the + and instead state that a,b≥0 a,bЄK? I'm not sure if that really proves it or not, but it's the best I have at the moment.
I was given much shorter proofs after I constructed this, and am aware it can be much shorter, but I mainly want to know if this is CORRECT or not.
Thank you!
What do you mean by "If a.b"? And your notation is invalid. You cannot say that a, and b are positive integers by writing (a^b)ЄZ+.
The symbol ^ is used to connect 2 statements. a, and b are 2 integers, not statements, so, you cannot write like that.
n seems to be jumping out of nowhere. When writing a formal proof, everything must be defined. What is n doing there? What's the relation between n, and the existing variable(s)?
[X]
And what's the connection between n, and a, b?
I was told ^ simply means "and" so I thought it would be appropriate.
a·b is a common way to say "a multiplied by b." Even calculators use the notation of a centered dot to represent multiplication.
I first showed that a and b are both divisible by 2 since they are even.
I used n as an integer separate from the positive number definition to show that any even number is divisible by 2 and therefore the multiplication of two even numbers is divisible by 4.
Well, yes, I know it's multiplication sign, but why are you putting 'If' in front of a.b? It doesn't make much sense.
No, you don't need to show that, it's how even numbers are defined to be.
Even integers are integers that are divisible by 2. So if a, and b are even integers, then they are divisible by 2. You don't need to prove it.
You must introduce the appearance of n, like this:
a \mbox{ is an even integer } \Rightarrow \exists n \in \mathbb{Z} : a = 2n
b \mbox{ is an even integer } \Rightarrow \exists m \in \mathbb{Z} : b = 2m
":" stands for 'such that'
\exists means 'there exists'.
One important thing you should note is that, in a formal proof, you should always defined/introduce every single variable. How they are defined, where they come from, blah blah blah. You cannot just throw them out of nowhere.
The first line I used to state mathematically what the problem said, which is why I said if, because it has to exist. However, now I believe ∃ would probably be a better way to start it. So, how does this look?
The following is simply how I restate the problem, saying it exists, that they are integers, and that they are even. I believe the ^ is appropriate here since those are statements?
∃ 4|(a·b) and 2|a ^ 2|b : a,bЄZ
Now I introduce n and m. Since I defined a and b as even in the last step, I believe it would be unnecessary here?
a → ∃n Є Z : a = 2·n
b → ∃m Є Z : b = 2·m
I show that 4|[(2·n)(2·m)] relates to 4|(a·b):
4|[(2·n)(2·m)]
4|(4·n·m) → 4|(a·b)
Therefore;
∴ 4|(a·b)
[X]
Is anything wrong with this proof?
Is the notation ЄZ+ correct for positive integers? (I at first read the question wrong and thought it said POSITIVE even integers, which is why I tried incorporating that, but I'm curious if it's correct for future use).
Apologies if it seems I'm making obvious mistakes, I'm new to writing proofs and this is the hardest one I've yet to write since the class pretty much just started. I'm not yet familiar with the notation of things.
No, that's not how you would use 'exists'. 'exists' (\exists), and 'for all' (\forall) only goes with variables. 4|(a.b) is a statement (4 divides a.b).
Here's some ways you can use 'exists', and 'for all' in making statements.
  • a \vdots 3 \Rightarrow \exists k \in \mathbb{Z} : a = 3k
  • x \ge 0, \forall x \in \mathbb{N}
  • \exists x \in \mathbb{Z} : x + 3 = 0
If you want to write down what your problem asks Mathematically, I'd write like this:
\left. \begin{array}{l} a \mbox{ is even} \\ b \mbox{ is even} \end{array} \right\} \Rightarrow 4|(a.b)
This looks not bad.
4|[(2·n)(2·m)]
4|(4·n·m) → 4|(a·b)
You can write it a little bit reverse. We always go from what we know to be true, to what we need to prove. Like this:
We have:
4|(4.m.n) (this is because there's a factor 4 in 4.m.n, hence 4 divides 4.m.n)
\Rightarrow 4|((2.m).(2.n))
\Rightarrow 4|(a.b)
Yup, \mathbb{Z} ^ {+} stands for the set of positive integers.
Everything is hard in the beginning, but I assure you it'll get easier as you practice more and more. Don't worry. Just try our best, and you'll get what you want. :)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
