Proofs for Dirac delta function/distribution
Wishe Deom
[SOLVED] Proofs for Dirac delta function/distribution
Prove that
<br /> \delta(cx)=\frac{1}{|c|}\delta(x)<br />
\delta(x) is defined as
<br /> \delta(x)=\left\{\stackrel{0 for x \neq 0}{\infty for x=0}<br />
It has the properties:
<br /> \int^{\infty}_{-\infty}\delta(x)dx=1<br />
<br /> \int^{\infty}_{-\infty}f(x)\delta(x-a)dx=f(a)<br />
Two expressions D_{1} and D_{2} involving \delta(x) are considered equivalent if
<br /> \int^{\infty}_{-\infty}f(x)D_{1}dx = \int^{\infty}_{-\infty}f(x)D_{2}dx<br />
Starting from
<br /> \int^{\infty}_{-\infty}f(x)\delta(cx)dx = \int^{\infty}_{-\infty}f(x)\frac{1}{|c|}\delta(x)dx<br />
I make a substitution u=cx, and du=cdx.
<br /> \frac{1}{c}\int^{\infty}_{-\infty}f(u/c)\delta(u)du = \frac{1}{|c|}\int^{\infty}_{-\infty}f(x)\delta(x)dx<br />
Substitute f(u/c)=g(u), and on right side evaluate integral.
<br /> \frac{1}{c}\int^{\infty}_{-\infty}g(u)\delta(u)du = \frac{1}{|c|}f(0)<br />
Evaluate left side.
<br /> \frac{1}{c}g(0)= \frac{1}{|c|}f(0)<br />
By x=u/c, g(0)=f(0), so
<br /> \frac{1}{c}f(0)= \frac{1}{|c|}f(0)<br />
So, I got this far, but I don't understand where the absolute value on the right side comes from.
see, when c is negative, your limits on the integral after the substitution change signs, therefore, for negative c, you should have a modulus sign.
If c is negative, when you do the substitution u=cx the u-limits become +infinity to -infinity, instead of -infinity to +infinity for x.
Ok, thank you both. In retrospect, that was kind of obvious :P
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
