Proofs of max and min formulas for 2 numbers
The discussion revolves around proving the maximum and minimum formulas for two numbers, x and y, specifically max(x,y) and min(x,y). Participants are exploring the mathematical reasoning behind these formulas and considering different approaches to their proofs.
  • The original poster attempts to prove the formulas using informal reasoning and questions whether a more formal approach, such as the trichotomy law, would be appropriate. Other participants suggest using x and y directly instead of introducing variables a and b.
The discussion is active, with participants providing feedback on the proofs and suggesting improvements. Some participants express that the reasoning could be more concise and focused on the essential elements of the cases being considered.
Participants are considering the implications of using different proof techniques and the clarity of their arguments. There is an emphasis on ensuring that all cases are covered in the proofs for maximum rigor.
nike5
The maximum of 2 numbers x and y is denoted by max(x,y) and the minimum of 2 numbers
x and y is denoted by min(x,y). Prove that max(x,y) = (x + y + l y - x l) / 2
and min(x,y) = (x + y - ly - xl ) / 2.
Theorem. max(x,y) = (x + y + l y - x l) / 2
Proof. Let x and y be arbitrary real numbers. Then the midpoint between x and y is represented by (a + b) / 2. Therefore, (a + b ) / 2 is l y - x l / 2 numbers less than
max(x, y). Then adding l y - x l / 2 to (a + b ) / 2 yields ( x + y + l y - x l / 2 = max(x, y).
Theorem. min( x, y) = (x + y - l y - x l) / 2
Proof. Let x and y be arbitrary real numbers. Then the midpoint between x and y is represented by (a + b ) /2 . Therefore, (a + b) /2 is l y - x l) / 2 greater than min(x, y). Then subtracting l y - x l) / 2 from (a + b ) / 2 yields (x + y - l y - x l) / 2 = min( x,y).
Is the reasoning in these proofs too informal? Should I instead use the trichotomy law and prove the formulas by the three cases
Hi nike5! :smile:
(you should be able to find a | on your keyboard somewhere near the " :wink:)
nike5 said:
… Should I instead use the trichotomy law and prove the formulas by the three cases
Short answer … yes! :biggrin:
And you should get rid of the a and b. You're given x and y, so use them instead.
Proof take 2
Theorem. max (x, y) = (x + y + |y - x|) / 2
Proof. Let x and y be arbitrary real numbers. We will consider three cases.
Case 1. x = y. Then max ( x, y) = x = y = ( x + y) / 2 = [(x + y) / 2] + 0
= [(x + y) / 2] + ( 0 = y-x) = [(x + y) / 2] + ( |y - x|) = [(x + y) / 2] + ( |y - x|/ 2)
= (x + y + |y - x |) / 2.
Case 2. x < y. Adding (-x) to both sides of x < y we get (y-x) > 0.
Then max (x, y) = y = (2y) / 2 = (y + y) / 2 = ( y + y + x + (-x) / 2 = (x + y + y - x) / 2
Hence, since y- x > 0, ( x + y + |y - x|) / 2.
Case 3. x > y. Then max (x, y) = x = (2x) / 2 = (x + x) /2 = ( x + x + y + (-y)) / 2
= ( x + y + (-y) + x) / 2. Adding (- x) to both sides of x > y we get ( y - x) < 0. Then, by the
definition of absolute value, |y - x| = (- y) + x. Substituting |y - x| for ( -y) + x in
( x + y + (-y) + x) / 2 we get max ( x,y) = x = ( x + y + |y - x|) / 2.
Thus, since this covers all cases for every pair of real numbers x and y, we can conclude that max (x,y) = (x + y + |y - x|) / 2. QED
Better?
nike5 said:
Better?
Yes! :smile:
But you can cut out a lot of it …
for example:
and (x + y + |y - x |) / 2 = (x + x + 0)/2 = x :wink:
(and similarly for Cases 2 and 3)
Thanks for the help Tim:smile:
  • · Replies 21 ·
