- #71
PAllen
- 2,432
The definition of proper distance doesn't use anything related to the NNT condition or any coordinates at all. Check the definition section again to see this. The NNT idea comes in with an attempt to say something limited about the extremal properties spacetime geodesics. I establish that without restrictions in nearby paths, no max/min statement is possible at all, even in SR. So I am only looking here to propose a restricted sense in which you can declare a max/min property.pervect said:Here's the problem I see. Your NNT (Non Negative time) condition isn't as innocent as you think. You've already noted that it's not coordinate independent, and I believe it's going to introduce coordinate dependency into your definition.
I am not referring to these geodesics at all. Much later, in talking about physical meaning of proper distance I talk about 3-geodesics in a carefully chosen simultaneity slice. But in this section I am only talking about spacetime geodesics and spacetime paths.pervect said:You start out by making some space-time slice in order to be able to distinguish out negative time from positive time, which means you have defined space-like slices of simultaneity.
Now, the interesting part comes in just when the geodesics lying entirely in this space-like slice are not the same as the geodesics in space-time.
pervect said:Clearly, if they are different, and if we take our initial point and final point as being "at the same time", some section of the geodesic in space-time is going to violate your NNT condition.
So what's going to be the net result? Well, if the end time is the same as the start time, not even a small section of the geodesic can ever advance forward in time. So the entire geodesic must lie within the surface of simultaneity.
As a consequence, your approach doesn't seem to be any different than just specifying your space-like slice by fiat.
This observation gets at a small omission in the extremal conjecture section, where an additional issue I dealt with later (in the "meaning of proper distance" section) I forgot to include in the geodesic extremal conjecture. I thought of this early today, but haven't had a chance to fix it. That, indeed, is related to what you say here.
I meant to specify that a spacelike geodesic is a local minimum related to NNT paths in a coordinate system that includes that geodesic as an NNT path. This is they way I did it later.
Then I think there is nothing wrong with my conjecture. I will see if I can still edit the original post, otherwise I will post a corrected version of the extremal conjecture.
