Propulsion system for a single engine propeller driven a/c
The discussion focuses on selecting a propulsion system for a single-engine propeller-driven aircraft, with a particular interest in diesel engines due to their efficiency and cost-effectiveness. The designer is considering a range of options, including turboprop and piston prop engines, but finds aero-diesel engines increasingly appealing. The project requires a personal aircraft design with a range of 1600 km and a single engine. The designer acknowledges a trade-off between power-to-weight ratio and fuel cost. Input from others on the best engine choice is welcomed.
ravachol
for my design project, i have to consider a feasible prop systm for a single engine propellr driven aircraft and I am thinking about diesel engines. they seem very efficient and cheap for aircraft propulsion.
ill have a small number for power/ weight ratio but it will be cheaper and it wll use diesel fuel
can anybody offers turboprop or piston prop ?
i think i didn't write the problem obviously.
I have to design a personal aircraft with 1600 km range and the pav must have one engine.
At first glance, I chose a turboprop engine but then aero-diesel engines became more reasonable for me.
If you have any opinion, I will be glad to hear
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
