How to Use Induction to Prove 2^n+1 = 2^(n+1)-1?
  • Thread starter Thread starter jonroberts74
jonroberts74
2^0+2^1+2^2+...+2^n=2^{n+1}-1;n \ge 0
P(0) 2^0=2^{0+1}-1 \rightarrow 1=1
P(k) = 2^{k+1}-1
1+2+2^2+2^k+2^{k+1}=2^{k+1}-1+2^{k+1}
2^{k+2}-1 = 2^{k+1}-1+2^{k+1}
= 2^{k+1}(1+1)-1
= 2^{k+1}(2)-1
= 2^{k+1+1}-1
= 2^{k+2}-1
Your solution is fine, but your presentation is hard to follow. As you know, you need to prove that ##2^0=2^1-1## and then that if ##1+\cdots+2^{k}=2^{k+1}-1## then ##2^0+\cdots+2^{k+1}=2^{k+2}-1##. To prove the former, I would just write ##2^0=1=2^1-1##. The calculation that proves the latter is much easier to follow in this form:
$$2^0+\cdots+2^{k+1}=(2^0+\cdots+2^k)+2^{k+1} =(2^{k+1}-1)+2^{k+1} =2\cdot 2^{k+1}-1=2^{k+2}-1.$$ Next time use the template. The moderators may delete your post if you don't.
Likes 1 person
You can also prove this without induction.
Proposition: ##x^n - 1 = (x - 1)(1 + x + ... + x^{n-1})##.
The above is easily shown by distributing the entire ##(1 + x + ... + x^{n-1})## on the right hand side to yield: ##(x + x^2 + ... + x^n) - (1 + x + ... + x^{n-1})##.
Now if you plug in 2 for x, you get what you were looking to prove.
Or, alternatively$$
s = 2^0+2^1+...+2^n$$ $$
2s=2^1+2^2+...+2^n+2^{n+1}$$Subtract the first from the second:$$
s=-2^0+2^{n+1} =2^{n+1}-1$$It's just the old geometric series trick.
I think what you are struggling with is a way of thinking about the algebra logic.
You assume P(k) in the induction. (Make certain to state this as an assumption.) You want to show P(k+1) holds by starting with the left-hand side and using the P(k) assumption. I'm writing ? to indicate that I stop and think, what type of relation can I make from the known information.
##2^0 + 2^1 + \cdots + 2^k + 2^{k+1} = ?## Given LHS.
##= (2^0 + 2^1 + \cdots + 2^k) + 2^{k+1} = ?## Recognize P(k)
##= (2^{k+1} -1) + 2^{k+1} = ?## Substitute P(k).
##=2(2^{k+1}) -1 = ? ## Regrouping.
##=2^{(k+1)+1} - 1## Determined RHS.
Your solution has a lot of extraneous information, so I think you are trying to "balance" an equation. You really just have to set up a series of relations.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
