Prove A contains all natural numbers ≥ n_0
The discussion centers on proving that a set A of natural numbers, which contains a specific number n_0 and includes k+1 whenever it contains k, must contain all natural numbers greater than or equal to n_0. Participants clarify that while n_0 is included in A, it does not imply that A cannot contain numbers less than n_0. A formal proof should demonstrate that for any natural number n_1 greater than or equal to n_0, n_1 is also in A. The importance of a rigorous approach to proofs is emphasized, as assumptions can lead to incorrect conclusions. Overall, the conversation highlights the need for clarity and formality in mathematical proofs.
r0bHadz
Prove that if a set A of natural numbers contains n_0 and contains k+1 whenever it contains k, then A contains all natural numbers ≥ n_0
I'm just confused by the question, please don't answer it.
Logically it makes sense that if n_0 is in the set A, then n_0 can = k, and from there we see that the set contains all natural numbers larger than n_0 including n_0
My question is, the way this question is worded, "then A contains all natural numbers ≥ n_0," this is not saying that the set A can't have natural numbers less than n_0 though, correct?
Correct.
The set may contain other natural numbers.
( You missed a [/itex] code after the ##n_0##.)
Likes r0bHadz
SammyS said:
Correct.
Ah, gotcha. The way the question was worded just kinda threw me off. I guess the proof just involves a mention of n_0 and the well ordering principle
Is this proof sufficient:
Since n_0 is in the set, let's assume, by the well ordering principle that n_0 is the smallest natural number in the set.
Setting k=n_0 we now have n_0 and n_0 + 1 in the set. If we let k = n_0 + 1 then n_0 +2 is also in the set.
It becomes oblivious that the set contains all numbers including and greater than n_0
As you concluded previously, there may be numbers in set A which are less than ##n_0## .
So, it's not correct to assume that ##n_0## is the smallest natural number in set A.
The form of the proof should be: Suppose natural number ##n_1 \geq n_0##. Then prove ##n_1 \in A##. It is not enough to just say that it is obvious. That may be true, but you should learn how to do a formal proof because there can be ugly surprises in things that look obvious.
Likes SammyS
Right but I thought in the context of this problem those numbers don't matter? The reason why I wrote to assume n_0 is the smallest is just to make the problem simpler. It's only asking me to prove that A contains all numbers equal to or greater than n_0 I don't see how numbers smaller than n_0 are relevant
Gotcha I guess I'll have to work on it and report back
