Prove a limit using inequalities
  • Thread starter Thread starter Hernaner28
    Inequalities Limit
Using the inequalities sin x ≤ x ≤ tan x, the limit lim_{x → 0} (x/sin x) = 1 can be proven by establishing that for every epsilon > 0, there exists a delta > 0 such that |x - 0| < delta implies |x/sin x - 1| < epsilon. The manipulation of the inequalities leads to the conclusion that (1/sin x) ≥ (1/x) ≥ (1/tan x), allowing for the derivation of bounds on |(x/sin x) - 1|. By factoring and applying the inequalities, it is shown that |(1/sin x - 1/x)| can be controlled, leading to the assignment of delta in terms of epsilon. Ultimately, this confirms that |x/sin x - 1| can be made less than epsilon, proving the limit.
Hernaner28
Using the inequalities: \sin x \leq x \leq \tan x valid in a zero range, prove that:
\displaystyle\lim_{x \to{0}}{\frac{x}{\sin x}}= 1
Thank you!
I'm rather unsure about this, but I'm deeply interested in the answer. I have attempted a solution that may or may not be correct.
What we're trying to prove is that for every epsilon > 0, there is some delta > 0 such that for all x, |x- 0| < delta and |x/sinx - 1| < epsilon. Because of this, we can assign a delta a particular value in terms of the epsilon.
if sinx ≤ x ≤ tanx, then (1/sinx) ≥ (1/x) ≥ (1/tanx)
Factor |(x/sinx) - 1| into |x| * |(1/sinx - 1/x)|
|(1/sinx - 1/x)| ≤ |1/sinx| + |1/x| < |1/sinx| + |1/sinx| by a manipulation of our given inequality = |2/sinx|
Let δ = min(1, ε/|2/sinx|)
from |x| < δ
we have |x| < ε/|2/sinx|
|x|*|(1/sinx + 1/x)| < ε/|2/sinx|*|(1/sinx + 1/x)|
|x/sinx - 1| < ε/|2/sinx|* |2/sinx| by inequality above
|x/sinx - 1| < ε
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
  • · Replies 20 ·
