Prove f is measurable on any closed set
jinsing
Prove if $f$ is measurable on R and C is any closed set, f^{-1}(C) is measurable.
Definition of measurability, closed sets etc.
I've been trying for a while to get this proof, but I seem to just end up stuck at the beginning. I think I want to point out that the complement of a closed set is an open set, and open sets are countable unions of open intervals, which are themselves measurable. But I'm not too sure, and I'd sure appreciate a gentle push in the right direction.
Thanks!
Yes, that is correct. So what is bothering you??
I guess I need help formalizing the argument. Would I just assume the hypotheses, point out by definition C' is an open set, and then just mention "open sets are countable unions of open intervals, which are measurable?" Doesn't seem too rigorous..
It's rigorous enough for me. (assuming you proved the things like any open set is the countable union of intervals).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
