Prove rectilinear motion given four-acceleration and four-velocity?
  • Thread starter learningphysics
In summary, Rindler's "Introduction to Special Relativity" asks the reader to show that given:\frac{dA}{d\tau} = \alpha^2 Uintegrating both sides, they get:A = {\alpha}^2 x^iwhich is the same as the equation for rectilinear motion.
learningphysics
Homework Helper
4,098
I've been struggling with this problem from Rindler's "INtroduction to Special Relativity"...
given a particle that has :
[tex]\frac{dA}{d\tau} = {\alpha}^2 U[/tex] where A is four-acceleration and U is four velocity... using integration prove that this implies rectilinear motion.
If I integrate both sides and set the constant of integration equal to zero I get:
[tex]A = {\alpha}^2 x^i [/tex]
I don't know where to go from here. I'd appreciate any help.
Can you proceed knowing that the dot-product of these four-vectors is [tex]U\cdot A =0 [/tex]?
Yes, definitely.
Ok... from here I can say:
[tex]A \cdot U = (\alpha^2 x^i) \cdot U[/tex]
then
[tex]0 = \alpha^2 x^i \cdot \frac{dx^i}{d\tau}[/tex]
[tex]0 = x^i \cdot \frac{dx^i}{d\tau}[/tex]
[tex]0 = \frac{1}{2} \frac{d}{d\tau}(x^i \cdot x^i)[/tex]
[tex]0 = \frac{d}{d\tau}(x^i \cdot x^i)[/tex]
[tex]K = x^i \cdot x^i [/tex] where K is a constant
taking c=1, and doing the dot product and replacing K with -K:
[tex]x^2 + y^2 + z^2 - t^2 = K[/tex]
Can the above equation be used to show that the object is moving in a straight line?
It's pretty late... so, I'm not 100% sure about this. See if this makes sense.
Rectilinear motion means that the particle travels along a straight line in space. That is, there is no "turning in space". On a spacetime diagram, this means that the motion must lie on a plane... the plane spanned by the timelike 4-velocity [tex]U^a[/tex] and the [necessarily spacelike*] 4-acceleration [tex]A^a[/tex]. (*Why? Since [tex]1=U^aU_a[/tex], then [tex]0=\displaystyle\frac{d}{d\tau}(U^aU_a)=2U^a\frac{d}{d\tau}U_a=2U^aA_a[/tex])
So, to ensure that motion lies on this spacetime plane, we should require that
the bivector [tex]U^{[a}A^{b]}=\frac{1}{2}(U^{a}A^{b}-U^{b}A^{a})[/tex] (similar to a cross product) is constant during the motion... that is, [tex]\displaystyle\frac{d}{d\tau}(U^{[a}A^{b]})=0[/tex].
Let's calculate
[tex]\begin{align*}
&=\displaystyle U^{[a}\left(\frac{d}{d\tau}A^{b]}\right)+
\left(\frac{d}{d\tau}U^{[a}\right)A^{b]}\\
&=\displaystyle U^{[a}\left(\alpha^2 U^{b]}\right)+
\left(A^{[a}\right)A^{b]}\\
&\stackrel{\surd}{=} \alpha^2 0 + 0
\end{align*}
[/tex]
Check for errors.
Oh... one more thing... as a variant of the above calculation
Let's calculate
[tex]\begin{align*}
\displaystyle\frac{d}{d\tau}(U^{a}A_{a})
&=\displaystyle U^{a}\left(\frac{d}{d\tau}A_{a}\right)+
\left(\frac{d}{d\tau}U^{a}\right)A_{a}\\
\displaystyle\frac{d}{d\tau}(0)
&=\displaystyle U^{a}\left(\alpha^2 U_{a}\right)+
\left(A^{a}\right)A_{a}\\
0&\stackrel{\surd}{=} \alpha^2 (1) + A^aA_a\\
-\alpha^2 &=A^aA_a
\end{align*}
[/tex]
which says (again) that [tex]A^a[/tex] is spacelike (assuming [tex]\alpha^2>0[/tex]), but now we learn that [tex]\alpha[/tex] is the magnitude of this spacelike [tex]A^a[/tex].
I just took a peek at my copy of Rindler, which suggests that [tex]\alpha[/tex] must actually be constant, which was not assumed anywhere above. But now, we can prove this starting from the given
[tex]\begin{align*}
\frac{dA^a}{d\tau} &= {\alpha}^2 U^a\\
A_a \frac{dA^a}{d\tau} &= A_a{\alpha}^2 U^a\\
\frac{1}{2}\frac{d }{d\tau} (A_aA^a) &= {\alpha}^2 (A_aU^a)\\
\frac{d}{d\tau}(A_aA^a) &= 0\\
A_aA^a &\stackrel{\surd}{=} \mbox{constant}\\
\end{align*}
[/tex]
Ok, now it's time to sleep. :zzz:
Hi robphy. Thanks so much for your help!
In that problem Rindler asks to show that given that given:
[tex]\frac{dA}{d\tau} = \alpha^2 U [/tex] ([tex]\alpha[/tex] not given as constant), show that the proper acceleration is constant and equal to [tex]\alpha[/tex].
I had no problem with those two parts. I believe I did exactly the same thing you did in the second and third parts of your posts.
Right afterwards Rindler says finally show by integration that the equation implies rectilinear motion. So it appears that showing that the magnitude of proper acceleration is constant is not enough to show rectilinear motion (at least in the context of the problem).
I will study the first part of your post which I really don't understand at the moment. I don't know about bivectors, so I can't verify. I really appreciate the time and effort you put into your post and helping me out. Thanks!
For anyone that's interested here's a different way I came up with to show rectilinear motion. Rectilinear motion means there is some inertial frame where the particle moves in a straight line. This amounts to showing that velocity // acceleration at all times in that frame.
From here, equating the space components of A and x^i we can say that:
s(t) = k1(t) u(t) + k2(t) a(t) [1]
s - displacement vector
u - velocity vector
a - acceleration vector
We can prove that if u(t1) // a(t1) at some time t1 then u(t) // a(t) for all t>t1
Assume u(t_k) // a(t_k) [2]
u(t_k + dt) = u(t_k) + dt a(t_k) [3]
by [2] and [3], u(t_k + dt) // u(t_k) [4]
by [1] and [2], s(t_k) // u(t_k) [5]
s(t_k + dt) = s(t_k) + dt u(t_k) [6]
by [5] and [6], s(t_k+dt) // s(t_k) [7]
by [4],[5] and [7], s(t_k+dt) // u(t_k+dt) [8]
and by [1] and [8], u(t_k + dt) // a(t_k + dt)
so I believe this pseudo inductive argument shows u(t)//a(t) for t>t1, and we can do the same thing for t<t1.
Finally, we need to see if there is a t1 when u(t1)//a(t1). We can satisfy this condition by picking an inertial frame where u=0 at some point in time. We can always pick such a frame. In any inertial frame where u=0 at some point in time, u//a at all times and so the object moves in a straight line.
1. What is rectilinear motion?
Rectilinear motion is a type of motion in which an object moves along a straight line with a constant velocity.
2. How can I prove that an object is moving in a rectilinear motion?
In order to prove rectilinear motion, you can use mathematical equations and measurements to show that the object is moving in a straight line with a constant velocity.
3. What is the difference between rectilinear motion and curvilinear motion?
The main difference between rectilinear and curvilinear motion is that rectilinear motion occurs along a straight line while curvilinear motion occurs along a curved path.
4. What are some examples of rectilinear motion in everyday life?
Some examples of rectilinear motion in everyday life include a car moving on a straight road, a train moving on a straight track, and a ball rolling in a straight line.
5. How does the study of rectilinear motion benefit us?
The study of rectilinear motion is important in understanding the laws of motion and mechanics. It also helps us to predict and analyze the motion of objects in real-world scenarios, which has practical applications in fields such as engineering and physics.
