Possible Measures of Angle C in Triangle ABC with Given Equation
  • Thread starter Thread starter utkarshakash
In triangle ABC, the equation a^4 + b^4 + c^4 = 2c^2(a^2 + b^2) leads to the conclusion that angle C must be either 45° or 135°. The discussion highlights confusion regarding the notation, as lowercase letters typically denote side lengths while uppercase letters represent angle measures. Participants suggest focusing on the expansion of (a^2 + b^2 - c^2)^2 to simplify the problem. Clarification of the variables is essential for accurate problem-solving. The conversation emphasizes the importance of correct notation in geometric equations.
utkarshakash
If in a triangle ABC, a^4+b^4+c^4=2c^2(a^2+b^2), prove that c=45° or 135°
Rearranging I have
(a^c-c^2)^2+b^2(b^2-2c^2)=0 \\<br /> <br /> cos C=\dfrac{a^2+b^2-c^2}{2ab} \\<br /> a^2-c^2=2abcosC-b^2
utkarshakash said:
If in a triangle ABC, a^4+b^4+c^4=2c^2(a^2+b^2), prove that c=45° or 135°<br />
You have things tangled up here, I believe. The lowercase letters a, b, and c typically represent the lengths of the sides. The uppercase letters A, B, and C typically represent the angle measures. Angle C would be the angle across from the side of length c. It&#039;s confusing to me that you use c for what appears to be a side length <u>and</u> an angle.<br /> <br /> <br /> <blockquote data-attributes="" data-quote="utkarshakash" data-source="post: 4234263" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> utkarshakash said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <h2>Homework Equations</h2><br /> <br /> <h2>The Attempt at a Solution</h2><br /> Rearranging I have <br /> <br /> (a^c-c^2)^2+b^2(b^2-2c^2)=0 \\&lt;br /&gt; &lt;br /&gt; cos c=\dfrac{a^2+b^2-c^2}{2ab} \\&lt;br /&gt; a^2-c^2=2abcosC-b^2 </div> </div> </blockquote>
Mark44 said:
You have things tangled up here, I believe. The lowercase letters a, b, and c typically represent the lengths of the sides. The uppercase letters A, B, and C typically represent the angle measures. Angle C would be the angle across from the side of length c. It's confusing to me that you use c for what appears to be a side length and an angle.
I have edited the question. Please see again.
Start by investigating the expansion of ##(a^2+b^2-c^2)^2##. Its pretty straightforward after that.
Thanks
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
