Prove that exp[A].exp = exp[A+B] only if A and B commute.
  • Thread starter Thread starter humanist rho
    Commute
humanist rho
Prove that eA.eB = e(A+B) only if A and B commute.
The attempt at a solution
I expanded both sides of the equation.
(1+A+A2/2!...)(1+B+B2/2!+..) = (1+(A+B)+(A+B)2/2!+..)
Now how to proceed ?
When you work out the brackets on the left hand side, you will get products like An Bm, where all the A's are to the left of the B's.
Now try to work out (A + B)n (e.g., start with (A + B)2). What do you need to get this in the same form?
Yeah,Now I got it.
Thank you.
Hi guys.
I was reading some QM and they mentioned exp(a+b)=exp(a)*exp(b) only if [a,b]=0; so I thought to go to the series definition of exp(x) and work it out by myself.
I do understand where the problem arises if suddenly a and b don't commute anymore, but that's not my problem. I want to write down the proof for exp(a+b)=exp(a)*exp(b) for "typical" a and b. iykwim
So, I came across your post and I would like some further details of how to preoceed in the proof.
this is what I have so far:
If:
<br /> exp(x)=\sum_{n=0}^{\infty}{\frac{x^n}{n!}} <br />
Then, for exp(a)*exp(b), we have:<br /> exp(a)*exp(b)=\sum_{n=0}^{\infty} \sum_{m=0}^{\infty}{\frac{a^n}{n!}}{\frac{b^m}{m!}} <br />
However, if I start with exp(a+b), I go like this:<br /> exp(a+b)=\sum_{n=0}^{\infty}{\frac{(a+b)^n}{n!}} = <br /> \sum_{n=0}^{\infty} \sum_{k=0}^{n}\frac{1}{n!}\binom{n}{k}a^k\cdot b^{n-k} =<br /> \sum_{n=0}^{\infty} \sum_{k=0}^{n}\frac{a^k}{k!}\frac{b^{n-k}}{(n-k)!}<br />
Summarizing, I get on one hand:
<br /> \sum_{n=0}^{\infty} \sum_{m=0}^{\infty}{\frac{a^n}{n!}}{\frac{b^m}{m!}} <br />
While on the other hand I get:
The two expressions look alike, but I can't put them in the very exact form. Could you help me here?
How should I proceed? I have a feeling that some index substitution is the answer, but I haven't figured out which one...
You are quite there. If you define n-k=l, then you obtain only the sum over n of expressions of k and l with the condition that k+l=n for k,l>=0. This sum can then be written as two sums for k and l from 0 to infinity in both cases.
This homework thread is 2 years old, so the OP is probably not working on the problem any more... :smile:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
