Prove that lim x -> 0 sin (1/x) doesn't exist
  • Thread starter Thread starter Portuga
    Sin
The limit of sin(1/x) as x approaches 0 does not exist because different sequences approaching 0 yield different limit values. Specifically, using sequences a_u = (π/2 + 2πu) and b_u = uπ, the limits of sin(a_u) and sin(b_u) converge to 1 and 0, respectively. This demonstrates that the function oscillates between these values without settling on a single limit. The discussion suggests that a more straightforward approach using sequences converging directly to 0 may simplify the proof. Ultimately, the conclusion is that the limit does not exist due to the differing results from the chosen paths.
Portuga
prove that
<br /> <br /> \lim_{x\rightarrow 0} \sin \left( \frac{1}{x} \right)<br /> <br /> doesn't exist.
<br /> \lim_{x\rightarrow0}\sin\left(\frac{1}{x}\right)=\lim_{u\rightarrow\infty}\sin u<br />
My strategy to solve this problem is to make u \rightarrow \infty through different paths and show that the limits are different.
So, first one is a_{u}=\frac{\pi}{2}+2\pi u,\,u\in\mathbb{N}. Second one is <br /> b_{u}=u\pi,\,u\in\mathbb{N}.
Both these have the same behavior as u \rightarrow \infty:
<br /> <br /> \lim_{u\rightarrow\infty}a_{u}=\lim_{u\rightarrow\infty}b_{u}=\infty.<br /> <br />
For with first one,
<br /> \begin{aligned}\lim_{u\rightarrow\infty}\sin a_{u} &amp; =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}+2\pi u\right)\\ &amp; =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}\right)\cos2\pi u+\sin2\pi u\cos\left(\frac{\pi}{2}\right)\\ &amp; =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}\right)\cos2\pi u+\lim_{u\rightarrow\infty}\sin2\pi u\cos\left(\frac{\pi}{2}\right)\\ &amp; =\lim_{u\rightarrow\infty}\cos2\pi u+\lim_{u\rightarrow\infty}\sin2\pi u\cos\left(\frac{\pi}{2}\right). \end{aligned}<br />
The limit <br /> \lim_{u\rightarrow\infty}\sin2\pi u\cos\left(\frac{\pi}{2}\right)<br /> tends to 0, as <br /> \cos\left(\frac{\pi}{2}\right)<br /> tends to 0, and <br /> \sin2\pi u<br /> is limited both upper and lower bound.
Therefore, <br /> \lim_{u\rightarrow\infty}\sin a_{u}=1.<br />
Now, <br /> \lim_{u\rightarrow\infty}\sin b_{u}=\lim_{u\rightarrow\infty}\sin u\pi=0,<br /> as, \forall u, u\pi is an multiple of \pi, which \sin is null.
Then, <br /> \lim_{u\rightarrow\infty}\sin b_{u}=0.<br />
Because of these two different results for different paths, it's true that <br /> \nexists\lim_{x\rightarrow0}\sin\frac{1}{x}.<br />
Am I correct?
Thanks in advance!
It looks okay, but could have been a lot simpler:
##\sin(\frac{\pi}{2} + 2\pi u) = \sin{\frac{\pi}{2}} = 1##
Also, you could just let ##a_u = \frac{1}{\frac{\pi}{2} + 2\pi u}## and keep the limits going to ##0##.
Likes Portuga
You are overthinking this. The individual functions are constant, their limit is easy to find.
Directly using sequences for the original function is better, because it avoids issues with the sign change at 0.
Likes Portuga
You mean, I should use <br /> a_{u}=\frac{1}{\frac{\pi}{2}+2\pi u},\,u\in\mathbb{N}<br /> and <br /> \lim_{x\rightarrow0}\sin\frac{1}{x}<br /> since the beggining, correct?
I thought you were using the idea of finding two sequences that converge to 0 but for which the two sequences of function values converge to different values. That looks fine as an approach. Changing the limit to ##\infty## requires a bit more justification.
Likes Portuga
Yes, that's exactly what's my initial approach was: two sequences converging to same value, but producing different limits with \sin \left( \frac{1}{x} \right).
One minor problem is that:
<br /> \lim_{x\rightarrow0+}\sin\left(\frac{1}{x}\right)=\lim_{u\rightarrow\infty}\sin u<br />
This is not fatal to your proof, but what you have is not quite right. It's better to stick with sequences going to 0.
