Prove that the rationals are dense
  • Thread starter Thread starter PcumP_Ravenclaw
The discussion focuses on proving the density of rational numbers between two given fractions, a/b and c/d, using the expression (a + mc)/(b + md) for positive integers m. Participants emphasize the need to show that this expression yields values strictly between a/b and c/d for all natural numbers m. The conversation highlights the importance of demonstrating that as m increases, the resulting rational numbers approach c/d without exceeding it, while remaining greater than a/b. Additionally, there is a recognition that while various formulas can generate rational numbers in this interval, none can encompass all possible rational numbers due to their infinite nature. The conclusion affirms that the proposed form effectively illustrates the density of rationals between any two fractions.
PcumP_Ravenclaw
Member warned about posting homework problems in non-homework sections
Show that there are infinitely many rational numbers ## \frac{a +m*c}{b + m*d} ## between the two rational numbers ## a/b## ##c/d ##. m is any positive integer.
My attempt:
first make common denominator
\frac{a*d}{b*d}##
##\frac{c*b}{d*b}
all numbers going from ##a*d## to ##c*b## divided by ##b*d## is in this interval. but these are finite so we have to increase the resolution. say multiply numerator and denominator by 1000 so now ## a*d*1000 ## to ## c*b*1000 ## divided by ## b*d*1000 ## .
It can be 100000 or anything very large say multiplied to infinity. how do I write this mathematically?
I am not sure I understand what you are trying to argue. Is ad<cb? How are you going to show the form stated in the problem?
Try looking at values for m from zero to infinity. You should be able to conclude that they are all in the interval [a/b,c/d).
My attempt:
\frac{a*d}{b*d}##
##\frac{c*b}{d*b}
I would do this in steps.
1. Show that ##\frac{a + mc}{b + md}## is less than c/d, for any choice of a positive integer m.
2. Show that ##\frac{a + mc}{b + md}## is greater than a/b, for any choice of a positive integer.
I am assuming that a/b < c/d.
If you can prove the above propositions, you're done, since m can be any integer in the set {1, 2, 3, ...}
Likes PcumP_Ravenclaw
I want to know how to derive the form ## \frac{a +m*c}{b+m*d} ##
I don't believe that you need to derive it, just show that there are an infinite number of rationals of this form between a/b and c/d.
I think that how it works is that given a/b and c/d, where a/b < c/d, the rational number with m = 1, ## \frac{a +1*c}{b+1*d} ##, is halfway between a/b and c/d. The same fraction with m = 2 gives a number that is 2/3 of the way between a/b and c/d. When m = 3, the fraction gives a number that is 3/4 of the way between a/b and c/d, and so on. These are the results I get when I choose a/b = 1/4 and c/d = 1/2, for a few selected values of m.
Is not halfway between ## a/b ## and ## c/d ## equal to ## \frac{a*d+c*b}{2*b*d} ##?
Yes it is.
Furthermore, the result for ##\displaystyle \ \frac{a+m\cdot c}{b+m\cdot d} \ ## depends not only on the two rational numbers, a/b and c/d but depends on the particular values used for each of a, b, c, and d .
For Mark's example with a/b = 1/4 and c/d = 1/2:
Using a = 1, b = 4, c = 2, d = 4 the result with m = 1 is: ##\displaystyle \ \frac{1+1\cdot 2}{4+1\cdot 4}=\frac38 \ .##
Using a = 1, b = 4, c = 1, d = 2 the result with m = 1 is: ##\displaystyle \ \frac{1+1\cdot 1}{4+1\cdot 2}=\frac13 \ .##​
Each of these results is between 1/4 and 1/2. Only the first is halfway between .
Can I say that my way to find rational numbers inbetween ## a/b ## and ## c/d ## is
## \frac{a*d+c*b}{m*b*d} ## where m is an integer from 1 to infinity. I realize that this will miss certain rational numbers but there is no way to encompass all the rational numbers using any formula involving integers like m? because between m = 1 and m = 2 there are infinitely many fractions? so the formula ##
## is also similar to mine missing some rational numbers so whose formula has higher resolution?
Thank you!
that only works for m=2. You need some more references to m in the expression.
Anyway, the way I read the question, you are required to show specifically that there are infinitely many of the form ##\frac{a +m*c}{b + m*d}##
It seems pretty straightforward that if m = 0, you have a/b and the limit as m goes to infinity will surely be c/d. From my vantage point, the only challenge would be to show explicitly that ##\frac ab \leq \frac{a+mc}{b+md} < \frac cd ## for all natural m.
This might be easier if you look at this as some sort of average.
Perhaps a is a total number of something done by b people, and c is the total number done by d people, the ##\frac{a+c}{b+d}## is the average done by all the people.
If every additional group of d people can do c things, than you can continue to average these events out by taking the total number done (a+mc) and dividing by the total number of people (b+md).
From this perspective, it should be clear that your mean can never exceed your largest value (c/d) and it can never be less than your smallest value (a/b).
I agree with haruspex here. (I usually do.)
If you can show that ##\displaystyle \ \displaystyle \ \frac{a+c}{b+d} \ ## is between ##\displaystyle \ \frac ab \ ## and ##\displaystyle \ \frac cd \,,\ ## then that will show that ##\displaystyle \ \frac{a+m\cdot c}{b+m\cdot d} \ ## is between ##\displaystyle \ \frac ab \ ## and ##\displaystyle \ \frac cd \ ## in general. Can you see why?
