Prove that the sequence converges
  • Thread starter Thread starter demonelite123
    Sequence
demonelite123
x_n = (n^2 / (n^2+1) , 1/sqrt(n)). prove that this sequence converges and find the limit.
so as n approaches infinite it is clear that x_n approaches (1,0). so using the definition of a convergent sequence, i pick an epsilon > 0 and i have to find some N such that when n>N, sqrt( 1/(n^2 + 1)^2 + 1/n ) < epsilon.
i tried fiddling with the inequality for a while but i can't seem to get it into a form where i can flip the inequality around and say n > (some function of epsilon). i tried combining the fraction into [(n^2+1)^2 + n] / [n(n^2+1)^2] and expanding it but i seem to be getting nowhere. can someone maybe give me a few hints or pushes in the right direction? thanks.
these type of proofs seem to be mostly exercises in manipulating inequalities which i am still inexperienced at.
If you are trying to make something like
\sqrt{a^2 + b^2}
small by making positive numbers a and b small, think about getting each of a and b less than 1. Then you will know a2 < a. Then if you let m = max{a,b}, how big can the square root expression be, and can you make it small by taking a and b additionally smaller than one?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
