Proving Validity of Argument Form with Contrapositive and Modus Ponens
  • Thread starter Thread starter illidari
    Argument Form
illidari
a) p
b) ~q -> ~p
c) q -> r
d) (r V t)-> s
proves e) s
Use a demonstration to show the following argument form is valid
1) ~q-> ~p proves p -> q contrapositive
2) p-> q , p proves q modus ponens
3) q->r , q proves r modus ponens
This is where I get iffy and confused, I think this is allowed but want to verify
4) (r V t) -> s proves ~s -> ~(rVt) implication to disjuction
5) ~s -> ~(rVt) proves ~s->~r^~t DeMorgans
6) ~s -> ~r ^~t proves sV~r^~t by implication to disjunction
7) sV~r ^ ~t proves sV~r specialization
8) sV~r, r proves s
does this look legit if anyone has taken a discrete math course that has a sheet with this stuff :(?
It looks to me like all this is given (renumbered so as to lessen any possible confusion with too many letters):
1. p
2. ~q -> ~p
3. q -> r
4. r V t -> s
and you need to show that if the hypotheses (1 through 4) are true, then s is true.
As you noticed, 2 is equivalent to p -> q, so the four hypotheses are the same if we replace the second one with p -> q.
So, we have p being true.
p being true and p -> q being true imply that q is true.
q being true and q -> r being true imply that r is true.
r being true implies that r V t is true. (t is completely irrelevant.)
r V t being true and (r V t) -> s being true imply that s is true.
1. p
2. ~q -> ~p
3. q -> r
4. r V t -> s
That was the part that bothers me. I think i have to somehow get rVt separated before I can get that claim.
rVt -> s and something else would have to prove rVt somehow :/
Then I can use rVt to move on. I'm suppose to write the rule name followed by which step I pulled the p and q from.
As Mark44 said, r being true implies r V t is true. It doesn't matter at all what t is. It could even be ~r. The point is that because you already know r is true (it is given), r v anything is automatically true by virtue of the fact that r is true.
The name of this rule is simply "addition". See http://en.wikipedia.org/wiki/Addition_(logic ) (or apparently disjunctive introduction if you want to be fancy).
Okay figured out my confusion , it was labeled generalization on my paper :)
I didn't realize p proves pVq meant that I could pick any q regardless if I had it proven or not.
Made this way harder than I should of >.<
Thanks !
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
