Prove using the formal definition of a limit
  • Thread starter Thread starter LOLItsAJ
    Definition Limit
LOLItsAJ
Prove using the formal definition of a limit that Lim x→4 x2 = 16
|f(x)-L| and |x-c|
Using epsilon/delta definition.
I've got that |x2-16| = |x-4||x+4|
I'm also pretty sure only |x-4| matters, since it is the same as |x-c|.
What would delta be? Since there's no coefficient of x to factor out, would delta = epsilon?
Another note: I really have no idea what I'm doing. I've based all my work off of prior examples, I don't understand how to "prove" the limit using the above information.
Hi LOLItsAJ! :smile:
If eg I specify .001, you have to find a range in which x2 lies between 15.999 and 16.001 :wink:
|f(x)-L| and |x-c|
You might start by using the formal definition of limit for the case you're working on:
Lim x→4 x2 = 16​
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
