Proving AB is Not Equal to CD in Euclidean Geometry
In Euclidean geometry, if line AB is parallel to line BC and line BC is parallel to line CD, then line AB is parallel to line CD only if AB is not equal to CD. If AB equals CD, they intersect at points A and B, violating the definition of parallel lines, which states they cannot intersect. The discussion highlights confusion over the definition of parallel lines, with some asserting that a line can be parallel to itself based on direction, while others emphasize that this contradicts Euclidean principles. The conversation also touches on the importance of precise definitions in geometry, particularly regarding lines and segments. Ultimately, the consensus is that in Euclidean geometry, a line cannot be parallel to itself, reinforcing the need for clarity in geometric definitions.
Imparcticle
If you had line AB is parallel to BC and BC is parallel to CD, is AB parallel to CD?
----> Not if AB=CD since a line (at least in Euclidean Geometry) cannot be parallel to itself.
How would you prove that AB is not line CD?
PLEASE NOTE: Base all your input in the realm of Euclidean geometry.
Mathematics news on Phys.org
If you refer to the line AB as the line going through two (different) given points, point A and point B, then clearly AB and BC both pass through the same point, point B.
Therefore if AB is not equal to BC, they will not be parallel.
Same argument goes for BC and CD.
BTW, the definition of "parallel" with which I'm familiar says that a line is parallel to itself.
No, the definition of parallel lines is: Two lines are parallel if and only if they do not intersect and they are not in the same plane. This definition holds in Euclidean geometry.
Let line AB and CD be parallel lines. Let AB=CD. Then C=A and B=D. The two lines have points in common, therefore they intersect. By definition, parallel lines do not intersect. Therefore a line cannot be parallel to itself.
All of this I base on the laws of Euclidean Geometry.
How about lines without points in common?
"AB is parallel to BC"
If both lines go trough a point B, they have at least one point in common. Therefore, they can't be parallel (that is, if a line cannot be parallel to itself).
I agree with you, koroljov.
now let us consider AC and GP and VL. Prove that AC and VL are two different lines and they are both parallel to GP.
Please be more careful in quoting definitions. That definition is completely wrong!
I would also point out that if AB and CD are lines such that AB= CD, it does NOT follow that "C= A and B= D". That does not follow even for line segments rather than lines.
I've always believed two parallel lines could be AT THE SAME PLANE...
yeah "is parallel to" is even equivalence relation:
1. AB || AB
2. if AB || BC then BC || AB
3. if AB || BC & BC || CD then AB || CD
what's all the fuss about everybody? a line can always be parallel to itself
http://dictionary.reference.com/search?q=parallel
dictionary.com said:
Of, relating to, or designating two or more straight coplanar lines that do not intersect.
I always thought that to be parrallel you only needed the same slope in two lines.
Also, when he said AB = CD, I don't think he was multiplying, instead he was saying the lines have the same end points. A = C and B = D.
So... is x^2 'parrallel' to x^2+1?
Yes, that's true but that statement, requiring trigonometry, is too complicated to be considered a definition.
Yes, everyone understood that. My point was: first LINES don't have endpoints, line SEGMENTS do (and we were talking about "parallel" lines which doesn't apply to segments). Also, even for line segments AB, CD, in which A, B, C, D ARE the endpoints, AB= CD does not necessarily imply A= C and B= D. It might be that A= D and B= C!
No, the concept of parallel we are talking about here (Euclidean geometry) only applies to straight lines.
Certainly, you could extend the concept of parallel (in several different ways, possibly) to curves. I suspect that in any reasonable definition of "parallel" for curves, the graphs given by y= x<sup>2</sup> and y= x<sup>2</sup>+ 1 would be parallel.
According to this source:
http://aleph0.clarku.edu/~djoyce/java/elements/bookI/defI23.html
Parallel lines are defined as follows:
Parallel straight lines are straight lines which, being in the same plane and being produced indefinitely in both directions, do not meet one another in either direction.
How is that different from what I stated? (I am inquiring with genuine curiosity, not to be defensive)
I'm just throwing something out here, but regarding "parallel" curves (of which I've never heard any definition) such as x^2 and x^2 + 1, I would imagine that this could be solved by use of derivatives. Since the derivative is 2x in both cases, then they could be considered parallel.
However, since no actual definition exists, you could theoretically create any critieria you wish. ;)
If the first curve were sin x and the second one were sin (x + 5) + 5, you'd probably say they were parallel even though their derivatives are different. You tend to say two things are "parallel" when one can be transformed into the other solely by translation.
http://aleph0.clarku.edu/~djoyce/ja...okI/defI23.html
Yes, but your original post was (I just "cut and paste" it):
"No, the definition of parallel lines is: Two lines are parallel if and only if they do not intersect and they are not in the same plane. This definition holds in Euclidean geometry."
Specifically, you said "they are not in the same plane" which is not what you intended.
oh, thanks!
I still don't understand how only one line, A can be parallel to itself.
Depends entirely on the specific definition. I, personally, would be inclined to say that two lines are parallel if and only if they have no point in common so that a line is not parallel to itself, but if you are focusing on direction (two lines are parallel if and only if they have the same direction) you could certainly say a line is parallel to itself. It's not a definition I would use but I wouldn't argue with Hurkyl's use of it.
HallsofIvy said:
Depends entirely on the specific definition. I, personally, would be inclined to say that two lines are parallel if and only if they have no point in common...
If that's true, then skew lines are parallel.
But that isn't the definition given by Euclid. I am focusing on Euclid's definition.
Anyway, saying that a line is parallel to itself does not satisfy the hypothesis of the definition (the second one) that you gave. The hypothesis says "two lines are parallel if...", but if a line is parallel to itself, then there is no need for a second line right? I'm probably mistaken though.
I don't challenge Hurkyl (among others including you HallsofIvy); I just ask how he arrives at conclusions or just ask him questions. I am doing the same here.
