Proving Det(B) = k*Det(A): A Fundamental Property of Determinants?
  • Thread starter Thread starter asap9993
    Determinant Proof
The discussion revolves around proving the property of determinants that states if a single row or column of a matrix A is multiplied by a scalar k, then the determinant of the resulting matrix B is equal to k times the determinant of A. Participants are exploring the implications of this property in the context of linear algebra.
  • Conceptual clarification, Assumption checking, Exploratory
  • The original poster attempts to set up a general n x n matrix and considers using cofactor expansion to demonstrate the property, but expresses uncertainty about its validity across all rows and columns. Some participants question whether the property of expanding along any row or column has been established in their course. Others suggest that it is acceptable to use known properties without proof in subsequent discussions.
The discussion is ongoing, with participants sharing their thoughts on the definitions and properties of determinants. Some guidance has been offered regarding the linearity of determinants and the relationship between rows and columns, but there is no explicit consensus on the proof itself.
Participants are navigating the challenge of proving a property that may not have been formally established in their coursework. There is a mention of the need to reference definitions and properties of determinants, as well as the implications of using established facts in proofs.
asap9993
I need help in proving that if B is the matrix that results when a single row or column of A is multiplied by a scalar k then det(B) = k*det(A).
The only way I could think of is setting up a general n x n matrix where all the entries on one of the rows or columns is multiplied by k. Then I could say that if one uses cofactor expansion along that particular row or column then the k factors out from all the cofactors.
However, the weakness to this method is that I would have to show that it also holds if one decides to expand along a row or column besides the one multiplied by k. I'm not sure if I could do that for every nth row or column.
Don't you already know that it doesn't matter which row or column you expand on, or has that not been proved in your course yet?
Of course everyone knows that. But how do you prove it for EVERY SINGLE POSSIBLE nth row or column for EVERY SINGLE POSSIBLE SQUARE MATRIX? Neither my teacher or my textbook proves it.
I can't just write "Take my word that it doesn't matter which row or column you expand upon" or "the textbook says so" on my proof.
If you could give some me help or tell me where I could find it, I would greatly appreciate it.
What definition of the determinant are you going off? Have you defined what happens to the determinant when you perform an elementary row operation on it?
I'll disagree a bit. If it's in your textbook and you've already covered it, it's fair game to use in a subsequent proof.
When you take math courses, there are all sorts of facts you're using without proof, like the properties of the real numbers. You're not expected to prove real numbers have all these properties before you use them in a linear algebra proof. So part of succeeding in the course is to figure out what you know and what you don't know, in the sense you can use this knowledge without necessarily proving it first.
When I took linear algebra, it was established pretty early that it didn't matter what row or column you expanded on to calculate the determinant, precisely to avoid the issue you're worried about now. That's what I meant by my question, whether it's already considered known to you.
For what I know, this fact for a row directly derives from the properties of the determinant. It is defined:
a) to be a linear application in the rows,
b) to give 0 if two rows are equal,
c) to give 1 if you calculate [tex]det(I_n)[/tex], with [tex]I_n[/tex] the identity matrix.
In particular the answer comes from a).
Instead for a column, you can think that the determinant of [tex]A[/tex] calculated along the i-th column is the same as the determinant calculated along the i-th row of the transpose of the matrix, [tex]^tA[/tex]. It is well known (and not so long to show) that [tex]det(A)=det(^tA)[/tex]. So the situation is reduced to the one explained before.
14K
