How Can You Verify the Reasonableness of E&M Homework Solutions?
mewmew
So our latest E&M homework assignment out of griffiths has a bit of a twist. For all of the answers that we get we have to show that they seem reasonable. I know for instance with a charged solid sphere of radius R you could take R<<r where r is the distance away from the sphere and see that it looks like a point charge.
I am unsure however how to best show that the E fields of a charged spherical shell and an infinite line charge should be show to be reasonable though. Any hints on limits that may be appropriate to take in these cases or other methods that I should look at? Thanks for any help.
At a point near the line charge and very far fom the sphere the result should reduce to the field from the line charge. At a point very far from the sphere on a line perpendicular to the line charge through the center of the sphere, the line charge field contribution should still dominate (1/r vs 1/r^2) and the contribution from the sphere should be point-like.
If the sphere is a neutral conductor whose charge redistributes in the presence of the line of charge, the field at any large distance from the sphere should reduce to the field from the line charge.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
