MHB Proving Equality in Real Numbers: The Case of a+b+c=abc
  • Thread starter Thread starter anemone
The discussion centers on proving the equality involving real numbers a, b, and c, where a + b + c = abc. The proof utilizes trigonometric identities, specifically relating the tangents of angles A, B, and C, to establish the required equality. It shows that if a = tan A, b = tan B, and c = tan C, then the relationship leads to the conclusion that a/(1-a^2) + b/(1-b^2) + c/(1-c^2) equals 4abc divided by the product of (1-a^2)(1-b^2)(1-c^2). The participants confirm they arrived at the solution using similar methods. The discussion highlights the interplay between algebra and trigonometry in solving the equation.
anemone
MHB
POTW Director
Let $a, b$ and $c$ be real numbers, all different from -1 and 1, such that $a+b+c=abc$. Prove that $$\frac{a^2}{1-a^2}+\frac{b^2}{1-b^2}+\frac{c^2}{1-c^2}=\frac{4abc}{(1-a^2)(1-b^2)(1-c^2)}$$
Mathematics news on Phys.org
(a + b+ c) = abc
so a = - (b+ c)/(1-bc)
if a = tan A , b = tan B , c = tan C
then tan A = - tan (B+C)
or A + B + C = npi
so 2A + 2B + 2C= 2npi
so tan 2A = tan (2npi- 2B - 2C)
or tan 2A = - tan (2B + 2C)
= (tan 2B + tan 2C)/( tan 2B tan 2C -1)
or tan 2A tan 2B tan 2C - tan 2A = tan 2B + tan 2C
or tan 2A + tan 2B + tan 2C = tan 2A tan 2B tan 2C
or
2tan A/(1-tan ^2A) + 2 tan B/(1-tan ^2 B) + 2 tanC /(1 - tan^2C) = 8 tan A tanC tanC/(( 1-tan ^2A)(1-tan ^2 B)(1- tan ^2C)
or
tan A/(1-tan ^2A) + tan B/(1-tan ^2 B) + tanC /(1 - tan^2C) = 4 tan A tanC tanC/(( 1-tan ^2A)(1-tan ^2 B)(1- tan ^2C)
or
a/(1-a^2) + b/(1-b^2) + c/(1 - c^2) = 4abc/(( 1-a^2)(1-b^2)(1- c^2))
kaliprasad said:
(a + b+ c) = abc
or A + B + C = npi
or
or
or
Thanks again for participating, kaliprasad and just so you know, you and I used the same approach to solve this problem!:)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
