Proving integration for a bounded increasing function
STEMucator
Suppose that f is a bounded, increasing function on [a,b]. If p is the partition of [a,b] into n equal sub intervals, compute Sp - sp and hence show f is integrable on [a,b]. What can you say about a decreasing function?
We partition [a,b] into sub-intervals.
For each i, we let : m_i = inf \left\{{f(x)|x_{i-1} ≤ x ≤ x_i}\right\} and M_i = sup \left\{{f(x)|x_{i-1} ≤ x ≤ x_i}\right\}
Now, we define s_p = \sum_{i=1}^{n} m_i Δx_i as the lower sum and S_p = \sum_{i=1}^{n} M_i Δx_i as the upper sum.
Some more info in my notes :
Let M = sup \left\{{f(x)|x \in [a,b]}\right\} and m = inf \left\{{f(x)|x \in [a,b]}\right\}. Then we get sp ≤ M(b-a) so the set of all possible sp is bounded above.
Let I = sup{sp} and J = inf{Sp}
Definition : if I = J, then f(x) is integrable.
Now another theorem I could use : For a bounded function f on [a,b]. f is integrable if and only if :
\forall ε&gt;0 there is a partition p of [a,b] such that Sp < sp + ε.
So we are given that f is a bounded increasing function. This means that m ≤ f ≤ M for some lower bound m and upper bound M. For any partition p of [a,b] into n sub-intervals, we also have :
Now before I jump any further I want to confirm the direction I'm going in. I have two theorems I provided and I'm wondering which one is more appropriate to use here.
I think I have an idea about how the information given relates, so continuing from my first post :
Now, writing out the upper sum we get : S_p = \sum_{i=1}^{n} M_iΔx_i and the lower sum : s_p = \sum_{i=1}^{n} m_iΔx_i
So we get :
S_p - s_p = \sum_{i=1}^{n} (M_i - m_i)Δx_i = \sum_{i=1}^{n} (f(x_i) - f(x_{i-1}))(\frac{b-a}{n})
I think this the path I'm trying to take.
Sorry for all the posting, but since no one has responded I believe I have pieced this puzzle together. So I'll write it out cleanly here.
So we are given that f is a bounded increasing function on [a,b]. This means that f(a) ≤ f(x) ≤ f(b) for any x in [a,b]. Hence f(a) is a lower bound for f and f(b) is an upper bound so that f is bounded. We need to show that for any ε>0, we can choose any partition p of [a,b] into n sub-intervals such that Sp - sp < ε. Suppose p is the partition \left\{{x_0, x_1, ..., x_n}\right\}.
We let : L = \displaystyle\max_{1≤i≤n}(x_i - x_{i-1}) &lt; \frac{ε}{f(b) - f(a)} = Q
Now, we define :
So we get :
S_p - s_p = \sum_{i=1}^{n} (M_i - m_i)Δx_i ≤ \sum_{i=1}^{n} (f(x_i) - f(x_{i-1}))L = (f(b) - f(a))L &lt; (f(b) - f(a))Q = ε
Hence f is integrable on [a,b] since Sp - sp < ε.
Is this good? It's my first time trying one of these.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
