Proving Union of Countable Sets is Countable
  • Thread starter IntroAnalysis
  • Tags
    Sets Union
In summary, if S is a countable set and {Ax}(s element S) is an indexed family of countable sets, then Union(s element S) As is a countable set.
IntroAnalysis
64
If S is a countable set and {Ax}(s element S) is an indexed family of countable sets, then
U(s element S) As is a countable set.
S is countable means it is finite or countable infinite ( S equivalent to J set of positive integers).
As is countable also finite or countable infinite. Can I assume it is a subset of S?
If x element Union(s element S) As
I don't know how to prove the union of As is 1-1 and onto J? Can someone suggest how to start?
Hello, thank you for your post. To prove that the union of As is countable, we can use a proof by contradiction. Assume that the union of As is uncountable. This means that there exists a bijection f: J -> Union(s element S) As, where J is the set of positive integers and As is the indexed family of countable sets.
Since f is a bijection, every element in Union(s element S) As is mapped to a unique element in J. However, since As is a subset of S, this means that every element in As is also mapped to a unique element in J. But this contradicts the fact that S is countable, as there cannot exist a bijection between a countable set and a subset of itself.
Therefore, the union of As must be countable.
Related to Proving Union of Countable Sets is Countable
1. What is the definition of a countable set?
A countable set is a set that can be put into a one-to-one correspondence with the set of natural numbers (1, 2, 3, ...).
2. What does it mean for a set to be countably infinite?
A set is countably infinite if it has the same cardinality as the set of natural numbers, meaning it can be put into a one-to-one correspondence with the natural numbers.
3. How do you prove that a set is countably infinite?
To prove that a set is countably infinite, you need to show that it can be put into a one-to-one correspondence with the set of natural numbers. This can be done by creating a function that maps each element in the set to a unique natural number, and showing that this function is both injective (each element in the set maps to a different natural number) and surjective (every natural number has an element in the set that maps to it).
4. What is the union of countable sets?
The union of countable sets is the set that contains all elements that are in at least one of the countable sets. For example, the union of the sets {1, 2, 3} and {2, 4, 6} would be {1, 2, 3, 4, 6}.
5. How do you prove that the union of countable sets is also countable?
To prove that the union of countable sets is countable, you can use a similar approach as proving a set is countably infinite. You need to show that the elements in the union set can be put into a one-to-one correspondence with the natural numbers. This can be done by creating a function that maps each element in the union set to a unique natural number, and showing that this function is both injective and surjective.
