Pspice Help: Plotting VTC of Circuit with Orcade Capture Lite
  • Thread starter Thread starter ACLerok
    Pspice
The discussion revolves around plotting the Voltage Transfer Characteristic (VTC) of a BiCMOS logic inverter circuit using OrCAD Capture Lite. Participants explore various methods and configurations for achieving this, including simulation settings and circuit component arrangements.
  • One participant seeks assistance with plotting the VTC and mentions difficulties with dividing output and input signals in OrCAD Capture Lite.
  • Another participant inquires whether the original poster is using actual PSpice code or the OrCAD GUI.
  • A suggestion is made to configure the simulation as a DC or parametric sweep and to add a trace of the output voltage divided by the input voltage after running the simulation.
  • There is a question about whether a single output variable can be used or if an operator is needed to divide the two signals.
  • A participant offers a detailed explanation of setting up the simulation profile, including the need to sweep a voltage source and the configuration of the input node.
  • After attempting the suggested method, the original poster reports that the plot does not appear correct, indicating potential issues with the circuit itself.
  • Another participant asks for details about the type of circuit being modeled and suggests posting screenshots of the circuit and results.
  • The original poster shares links to images of the circuit and output plots, asserting that the circuit is correct as per the lab manual.
  • One participant identifies a missing resistor in the circuit and suggests that the issue may still lie with the circuit or components used.
  • Another participant expresses uncertainty about the circuit's accuracy and questions whether the model components are comparable to real-world counterparts.
  • A suggestion is made to define the output node as a net alias and to check the orientation of the p-MOS FET in the circuit.
  • There is a discussion about the characteristics of the VTC produced by OrCAD and the potential need to use the D() function for more accurate derivative calculations.
Participants express various viewpoints on the configuration and accuracy of the circuit, with no consensus reached on the source of the plotting issues. Multiple competing views remain regarding the effectiveness of the simulation setup and the characteristics of the VTC.
Participants note potential limitations related to the accuracy of model components and the configuration of circuit junctions, as well as the need for further verification of the circuit's correctness.
ACLerok
I need help plotting the VTC of a given circuit. I tried dividing the output signal by the input signal put that does not work. Is there a function I can use to achieve this? I'm using Orcade Capture Lite by the way.
Thanks in advance.
Are you you using actual pspice code or the OrCad GUI ?
I'm using the GUI. They haven't really gone over the code in depth.
Configure your simulation as either a DC or parametric sweep. After running the simulation you should be able to add a trace with the output node voltage divided by the input node voltage.
Is it a single output variable or do I have to use an operator or analog function to divide the two signals? I can't find anything that resembles the VTC of this circuit. :confused:
I have not done this specifically before but I might still be able to help you. I apologize if I am over-simplifying your problem.
I am assuming that you are looking for a "Transfer Characteristic" for your circuit. I am also assuming that you have defined input and output nodes of your circuit. You just need to know which nodes you are interested in, they don't need to be labeled or anything.
After you enter your circuit in Capture you need to set up a simulation profile. Since you are plotting a voltage vs voltage curve you are going to need to sweep a voltage source to collect data points.
Make sure that the input node of you circuit has a VDC supply with the positive terminal connected to your input node and the negative terminal grounded. Configure your simulation to perform a DC sweep analysis through a range of values at specified intervals. Since it is your input voltage, the range of values will correspond to your desired X axis.
You do not need any probes on your circuit.
Run the simulation and it will bring up the PSPICE A/D window. You can then click on Trace > Add Trace. Narrow the results to voltages and select the output node. Enter a "/" to divide and then select the input voltage. When you add the trace you will have the input voltage on the X axis and the output voltage on the Y axis.
If you are still having problems you will need to give me more detailed information.
Thanks! I haven't tried it yet, but I will in a bit once I get some time.
I just tried it, and I was able to plot the output vs. the input. Unfortunately the plot did not come out looking correct. It might be the circuit that's causing the problem. I won't be able to mess around with it until tomorrow but I'll see if I can get it looking right then.
Thanks!
What type of circuit are you trying to model? You could post a screen capture of the circuit and the results if you like.
http://eden.rutgers.edu/~cjjacob/circuit.JPG"
http://eden.rutgers.edu/~cjjacob/voutvin.JPG"
http://eden.rutgers.edu/~cjjacob/vinvout.JPG"
It's just a regular BiCMOS logic inverter. I'm pretty sure the circuit is correct. I used the same parts that were suggested in the lab manual. i thought I'd also post what vin/vout looks like since it more resembles the VTC than the first plot.
Was missing a 100k Resistor between the output and ground. I just tested it with the resistor and I'm still getting the same output plots. :confused:
I am not familiar with that type of circuit. I was hoping someone with some more electronics experience would check it for accuracy.
Are you sure that all of the circuit junctions are correct? Also, are the characteristics of the model components that you selected comparable to their real-world counterparts?
It looks like your sweep simulation is properly configured so I would almost assume that the issue is with your circuit or the components.
The lab manual mentions no need to change and of the model parameters. Well I appreciate your efforts in helping me.
Two things:
- Define Vout as Net Alias of the output node, run a DC Sweep with V5 as sweep variable, and add a trace of Vout
- Looks like the curse of the p-MOS FET in Orcad haunts you. Looks like the source and drain terminals on M1 (the IRF9140 one) are swapped. Do a Mirror Vertically of that transistor.
I did this with a stock demo version of Orcad 9 and arrived to a decent VTC.
Cheers.
Jose
Thanks! One more thing, when taking the derivative I can just use the D() function correct? I just need to find the corresponding Noise Margins. I guess I can just 'eyeball' it or whatever, but I'd rather have a nice accurate value.
With the stock models of transistors, the VTC that OrCAD produces is very "squarish". I think you could take values of VIH and VIL accurate enough from the corners of the charasteristic.
However, the true VTC of a BiCMOS inverter is "rounder" and, in the case of arriving to a "rounded" VTC, you better use the D() function.
16K
  • · Replies 18 ·
  • · Replies 24 ·
15K
  • · Replies 20 ·
