Ptolemaic Model of the Solar System
In summary, the Ptolemaic model of the Solar system placed Venus inside the sun's orbit around the Earth, with its motion coupled to that of the sun to account for its retrograde motion. This was based on the observation that Venus never gets more than 47 degrees away from the sun in the sky. It wasn't until the 17th century that Galileo's observation of Venus's phases proved that it orbits the sun. The reason for this constraint in the Ptolemaic model is uncertain, but it was likely based on the belief that the sun was at the center of the universe and that planets should be arranged according to their distance from it. This belief was also used to justify the placement of Venus and
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
32,820
4,715
TL;DR Summary
The phases of Venus in the Ptolemaic model of the Solar System
OK, this is more on history of astronomy than anything else. I hope someone has an insight on how they were thinking of things back then.
The Ptolemaic model of the Solar system, i.e. the Geocentric model, placed Venus inside the sun's orbit around the earth. And to account for the retrograde motion of Venus, it is also orbiting around another center, very much like the model shown in this simulation (Flash required):
https://astro.unl.edu/classaction/animations/renaissance/ptolemaic.html
Now, here's my question. Why did the Ptolemaic model coupled the motion of Venus to the sun? You notice that the center of the smaller orbit of Venus is always in line with the sun. Anyone knows why those folks back then forced it to move this way? There must be a reason why they thought Venus was always very close to the sun and can't move too far away from it.
Zz.
Astronomy news on Phys.org
They were basing the model on what they saw, and Venus doesn't gets that far from the Sun in the sky; Never getting more than 47 degrees away. Ptolemy hypothesized that Venus was between the Earth and Sun, so this model seemed to be the best fit to match observation and maintain a geocentric view.
Several centuries later a transit was finally observed which seemed to bolster this view.
It wasn't until the 17th century that Galileo noted that Venus went through the full set of phases, meaning that it had to orbit the sun.
Likes Nik_2213 and PeroK
Do you know why they only saw such a small separation of Venus from the sun? Considering that Venus is rather bright in the sky, I would think that they would have noticed Venus through its entire orbit.
I'm having a minor issue here in trying to justify why they would constraint the motion of Venus. Without such constraint, then the Ptolemaic model can still explain the full phase of Venus that we see, because there's nothing then to say that Venus and the sun can't be on opposite sides, with the Earth in the middle.
The only rational reason that I can think of is that the gibbous/full phase of Venus occurs when it is on the other side of the sun from the earth, and thus, it is very small and very far in the sky. Maybe they could not see it till Galileo and his telescope?
Zz.
For what it is worth this is the mention that Ptolemy gives to the planetary positions in book IX of the Almagest (Toomer translation):
"First, then, [to discuss] the order of their spheres, which are all situated [with their poles] nearly coinciding with the poles of the inclined, ecliptic circle: we see that almost all the foremost astronomers agree that all the spheres are closer to the Earth than that of the fixed stars, and farther from the Earth than that of the moon, and that those of the three [outer planets] are farther from the Earth than those of the other [two] and the sun, Saturn’s being greatest, Jupiter's the next in order towards the earth, and Mars' below that. But concerning the spheres of Venus and Mercury, we see that they are placed below the sun’s by the more ancient astronomers, but by some of their successors these too are placed above [the sun’s], for the reason that the sun has never been obscured by them [Venus and Mercury] either. To us, however, such a criterion seems to have an element of uncertainty, since it is possible that some planets might indeed be below the sun, but nevertheless not always be in one of the planes through the sun and our viewpoint, but in another [plane], and hence might not be seen passing in front of it, just as in the case of the moon, when it passes below [the sun] at conjunction, no obscuration results in most cases. And since there is no other way, either, to make progress in our knowledge of this matter, since none of the stars has a noticeable parallax (which is the only phenomenon from which the distances can be derived), the order assumed by the older [astronomers] appears the more plausible. For, by putting the sun in the middle, it is more in accordance with the nature [of the bodies] in thus separating those which reach all possible distances from the sun and those which do not do so, but always move in its vicinity; provided only that it does not remove the latter close enough to the Earth that there can result a parallax of any size."
The 47 degrees is the (roughly) the maximum elongation of Venus that can be observed because of the size of its orbit. When it is close to the sun (angularly speaking) they couldn't see it. When you see Venus you probably will note that it has always been relatively soon after sunset when it is relatively far from the sun and high in the sky.
Likes jim mcnamara
Zz.
Here's Earth's orbit and Venus in relation. The yellow lines represent maximum angular separation from the Sun (viewed along red line.)
During the whole of the orbit as seen from the Earth, the maximum separation is ~47 degrees.
Likes Tazerfish
Thank you. I think this might do it for me.
Zz.
Likes Nik_2213
From the theory of relativity, there is no absolute center of the solar system. Putting the sun at the center (center of mass) makes all analyses much simpler. However one could just as well put the Earth at the center - getting very weird looking orbits.
Like this for the the inner solar system:
Red: Mars
Cyan: Venus
White: Mercury
Yellow: Sun
And this, if you expand out to include Jupiter and Saturn:
Likes Tazerfish, jim mcnamara, anorlunda and 4 others
ZapperZ said:
Summary:: The phases of Venus in the Ptolemaic model of the Solar System
I think the main thing they were thinking was that Earth is clearly the largest, most important location in their world. Any model (no serious Physics yet), however complicated and arbitrary, would need that basic tenet. @Janus shows (above) just how involved things would need to be but why would that have affected their opinions? The Creator made many things very complicated so why not the Universe?
It's hard to place oneself in a time like that. Even Keppler just formulated the 'rules' without including our basic laws of Gravity.
There is no evidence that astronomers considered the actual paths of the planets in this way before Kepler's Astronomia Nova (to the best of my knowledge). See https://www.keplersdiscovery.com/Hypotheses.html source (2/3 of the way down the page - requires flash for the animations).
As alluded to in the quote I provided in post 4, there was disagreement about the order of the Sun, Mercury, and Venus. Aside from the relative positions of Venus and Mercury never exceeding the elongations explained above, the periods of the rotations of their deferents are equal.
There's a cool way to think about this that I had not considered before I just found in this paper. Briefly: For the inferior planets the period of the deferent is equal to the sidereal period of the Earth and the period of their epicycles is equal to the planets' sidereal period.
For the superior planets the roles are reversed: the epicycle period is equal to the period of Earth and the deferent period is equal to their sidereal period. In the footnotes the author mentions that Copernicus realized these 'coincidences' can be explained with a heliocentric model.
Basically, this was the argument put forward by the Church when Galileo was arguing for the heliocentric model; That while the heliocentric model was indeed simpler, God could have made the universe any way he wanted.
By the time of Galileo's trials, Roman Catholic theologians and church hierarchy had been convulsed for centuries with the paramount issue of the poverty of Christ. The much discussed principle of Simplicity had generally been accepted and even codified by teaching, mendicant and cloistered orders. What is cloistered life if not simple?
Accepting the least or simplest explanation for astrological/astronomical observations meant accepting poverty as the fundamental path to God; a position literally anathema to wealthy church officials and vested interests even as Enlightenment and Reformation rose.
General relativity says both were right and both were wrong.
Related to Ptolemaic Model of the Solar System
What is the Ptolemaic Model of the Solar System?
The Ptolemaic Model of the Solar System is an ancient geocentric model that was developed by the Greek astronomer Ptolemy in the 2nd century AD. It states that the Earth is at the center of the universe and all other celestial bodies, including the Sun, revolve around it in perfect circles.
Why was the Ptolemaic Model of the Solar System significant?
The Ptolemaic Model of the Solar System was significant because it was the prevailing model of the universe for over 1,400 years. It provided a framework for understanding and predicting the movements of celestial bodies and was used for navigation and timekeeping.
How does the Ptolemaic Model of the Solar System differ from the modern heliocentric model?
The Ptolemaic Model of the Solar System differs from the modern heliocentric model in that it places the Earth at the center of the universe, whereas the heliocentric model places the Sun at the center. Additionally, the Ptolemaic model uses perfect circles to describe the orbits of celestial bodies, while the heliocentric model uses ellipses.
What evidence eventually led to the rejection of the Ptolemaic Model of the Solar System?
As scientific knowledge and technology advanced, astronomers began to observe and measure the movements of celestial bodies more accurately. This led to discrepancies and inaccuracies in the Ptolemaic Model, and eventually, the heliocentric model proposed by Copernicus gained more support due to its ability to explain these observations.
What impact did the Ptolemaic Model of the Solar System have on the development of astronomy?
The Ptolemaic Model of the Solar System played a significant role in the development of astronomy as it was the dominant model for centuries and laid the foundation for our understanding of the universe. It also sparked debate and further scientific inquiry, leading to the discovery of new evidence and the eventual acceptance of the heliocentric model.
  • Astronomy and Astrophysics
