Pulley Hoist Free Body Diagram
The discussion revolves around analyzing the forces in a pulley system, specifically focusing on the free body diagram and the tensions in the strings. Participants are seeking clarification on the calculations and relationships between the weights and tensions in the system.
  • One participant, Steve, expresses difficulty in understanding the forces acting on his pulley system and requests feedback on his sketch.
  • Another participant questions the feasibility of supporting a weight (W) with two strings of tension W/8, noting the angle between them complicates the situation.
  • Steve acknowledges that his calculations do not add up correctly and seeks assistance in determining the correct force multipliers for his pulleys.
  • It is suggested that if the string elements are approximated as vertical, the tension in the string would be W/5 to support the weight W.
  • Steve asks for confirmation on whether the weight is only carried by specific segments of the string and whether his calculations at certain pulleys are correct.
  • Another participant confirms that the weight is indeed carried by the specified string segments and corrects Steve's understanding of the tensions at the pulleys.
Participants exhibit some agreement on the relationships between the tensions and the weight, but there are still uncertainties regarding the specific calculations and configurations of the pulley system. The discussion remains unresolved in terms of final calculations and interpretations.
There are limitations in the assumptions made regarding the angles of the strings and the connections to the weight, which may affect the accuracy of the calculations discussed.
SGT_in_WI
Hi All,
I am an old dog, and rusty propeller head. I am having the most difficult time figuring out the forces on a pulley system I am working on. Can someone please review my sketch and tell me if I am even close. I would accept any suggestions and direction.
Much Obliged
-Steve
How can you support W/2 with two strings of W/8 tension (in addition, they have some angle between them!)
In addition, what happens to the end of the string (right side)? I think it should help to support the weight, too.
W/8 is a force, the tangent of a force is not well-defined.
Yes, I knew my W/2 did not add up correctly with 2 - W/8 loads. That is really where I need help.
W = Load
W/2 is a pulley at each end of the W
The angle is not counted at this time to avoid further confusion.
The end of the string is lifting W
I drew the tangent of middle pulleys for reference. The load on them will not affect my system I am building. I can calculate the load after I correctly figure out the force multiplier of my pulleys.
I hope I helped clear some up your questions.
The end of the string is lifting the same as all other parts. If we approximate that those string elements are vertical, we have 5 times the string tension holding that weight W, so string tension is W/5.
Thank you,
So that I have more understanding...
Is the weight only carried by the string between pulleys B-C, C-D, G-H, H-I , I-to end?
Also; Is my W/2 at pulleys C and H correct?
Do I substitute W/5 for where I have W/8 throughout the string?
-Steve
As the other parts are not connected to the weight... sure.
No, as you did not consider the end here.
Right
Thank you !
I believe I have all that I need.
Peace.
  • · Replies 31 ·
  • · Replies 32 ·
