Pumping Air Over Wing: Advantages & Disadvantages?
  • Thread starter Thread starter sid_galt
    Air
Pumping air over a wing can potentially enhance lift by reenergizing airflow and reducing turbulence, but it also risks detaching the boundary layer, which could increase drag and destabilize the aircraft. The effectiveness of this method may depend on the uniformity of air distribution across the wing. Additionally, the complexity of implementing air pumping systems, including ducting and energy requirements, poses significant challenges, particularly in terms of space typically reserved for fuel. The discussion also touches on the benefits of suction through porous wing walls, which can delay boundary layer detachment and reduce drag. Overall, while there are theoretical advantages to air pumping, practical implementation and potential drawbacks warrant careful consideration.
sid_galt
pumping air over wing??
So if hot/cold air is blown over the top surface of a small sized wing inflight which has a medium angle of attack, will it help in the lift or will it be a disadvantage?
I can only think of two things
1) Advantage: It will reenergize the airflow and help in reducing turbulence. Higher speed of wind will decrease pressure and increase lift though temperature of hot air might render the effects of the increased lift negligible.
2) Disadvantage: It might detach the boundary layer and might increase the drag substantially. If the blow speed gets even a little bit uneven, it may destabalize the aircraft considerably. It will result in uneven distribution of lift across the wingspan unless the air is uniformly blown all over the wing. This will result in increased stress.
What do you think?
If it turns out to be a disadvantage, would blowing the air under the wing instead of the top result in increased performance/lift?
Also a question about winglets. Why are winglets oriented with a positive angle and not a negative one? What if one has two winglets with + and - angles? Would that help in performance especially in small aircraft?
The suggestion is not new. However the problem with pumping air through pores in the wing is that large amounts of complex ducting and pumps will be required. Space in the wing normally reserved for fuel tanks will also need to be cut down.
Ducting, energy issues and pumps aside, will the suggestion actually work with either hot or cold air even on low Reynold number wings?
I don't see any advantage, besides I don't understand the advantages you posted. Pumping air will increase turbulence instabilities and drag.
The fact is it has been a lot of research in sucking air through a porous wing wall. The suction of air delays the boundary layer point of detachtment, decreasing drag.
Some turbomachine blades are machined in such a way to have such porous wall.
I was going to mention boundary layer control experiments using vacuums but Clausius beat me to it.
You may want to look at this link:
http://aerodyn.org/Drag/blc.html
It does talk about injection techniques.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
12K
