Solving Quantum Mechanical Potential Barrier Problem
Pilean
Hi!
I'm struggeling with a quantum mechanical problem.
An alpha-particle is "trapped" inside a uraniumcore, and the potential is simplified to
0 for R2 < r
V0 for R1<= r <= R2
0 for 0<= r < R1
I have calculated the transmission coefficient T = 1/(1+V02/(4E(V0-E))*sin2(sqrt(2m(V0-E)/hbar*(R1-R2)
I am now supposed to show that for k*dR >> 1, we have
T ~ K(E)*exp(-2k*dR)
Where dR = R2-R1
and k = sqrt(2m(V0-E)/hbar
And tell what K(E) is...
I have tried to use that sinx = (exp(ix)-exp(-ix))/2i, but it won't turn into the right expression..
A small additional question: For a infinate potential, is there any possibility for tunneling into this area? After what I understand from the infinite square well the probability for the particle to be in such a potential is zero?
Hope for some guidence on where to start :)
tell me is V0 > E if so then it should be sinh not sin
You are totally correct! Thanks!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
