QPSK Phase Shift: Symbol Change Explained
QPSK, or Quadrature Phase Shift Keying, utilizes coherent modulation where the receiver's reference clock is synchronized with the incoming signal. When a symbol change occurs in QPSK, the phase of the signal is altered to represent different data points, effectively encoding information through these phase shifts. The discussion highlights the importance of understanding how these phase shifts relate to the modulation process. Visual aids, such as diagrams, can help illustrate these concepts more clearly. Understanding QPSK phase shifts is crucial for effective communication in digital signal processing.
bhanesh
What is phase shift of qpsk when symbol change occurs ?
Can anybody explain please ?
QPSK is a form of "coherent" modulation. In coherent modulation the receiver contains a reference clock that is frequency locked to the received signal. Data is encoded by changing the received signal's phase and amplitude relative to the reference clock. Phase shifts are illustrated in the attached picture.
Did you look at Wikipedia? Have you any questions about their treatment of QPSK?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
