Quadrant determines the functions sign?
  • Thread starter Thread starter Keyser Söze
    Functions Sign
Keyser Söze
Hello! In my book we have defined trigonometric functions for all angles. Everything is pretty much the same as when we were using acute angles (same ratio of sides), except that in a quadrant one trigonometric function might be positive, another might be negative, so on. The book has a table for the six functions (sine, cosine, and tangent and their reciprocals) and what their signs are in each quadrant. What makes the signs change? It's much easier for me to remember something if I understand it. Thanks.
Mathematics news on Phys.org
Have you learned the ASTC quadrants mnemonic rule? That makes it a lot easier to remember the signs.
Ok, suppose I draw a vector (ie a line with some length L, making an angle A with the positive x-axis). The x-value lining up with the tip of the vector must be L*cos(A) and the y-value lining up with the tip of the vector must be L*sin(A). Try to draw a picture if you can't see it in your head. (Someone correct me if I'm wrong here) These can be taken as the definitions of the sine and cosine. Therefore for consistency, we require that the sine be positive in the first and second quadrants (where y is positive) and negative in the third and fourth (where y is negative), and that the cosine be positive in the first and fourth quadrants (where x is positive) and negative in the second and third (where x is negative). The signs of the other functions follow from this as they are all defined in terms of the sine and cosine.Cheers,
Nick
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
