Discover the Intervals of a Quadratic Function | Find Solutions and Graph
The discussion focuses on solving quadratic inequalities and absolute value inequalities. For the quadratic function y = x^2 - 10x + 24, the intervals where y > 0 can be determined by solving the inequality. Participants emphasize that solving the corresponding equality first is crucial for finding the correct intervals. For the absolute value inequality | -8x - 2| >= 10, the solution involves breaking it into two cases based on the sign of the expression inside the absolute value. Checking the domains of the solutions is highlighted as an important step to ensure consistency with the original problem.
fr33pl4gu3
If one plots the graph of
y = x2-10 x+24
which is a parabola, one observes that it is above the x axis, i.e. y > 0, for two intervals of the real line. (The union of these intervals constitute the set of solutions of the quadratic inequality at the beginning of this question.)
Find the intervals.
How do you do this anyway??
Is it like take x = 3, and put it in and come out with y = 3, the the intervals would be (3,3)
So you're trying to find the range of x values that satisfy the equality y>0? If you set x^2 - 10x + 24 > 0 and solve normally, you should be fine. Is this correct?
V
Yes, but i already solve that solution, but here is another one, that is similar to the previous one.
The solution set of x values of the ineqality
|-8 x-2| >= 10
may be expressed as the union of a pair of intervals of the real line. What are those intervals?
how to solve this??
I keep on getting the wrong answer.
:cry:
The best way to solve a problem like this is to first solve the equality. That is exactly what you did in the first problem.
That is, first solve |-8x- 2|= 10 which is the same as solving -8x- 2= 10 and -8x- 2= -10 which is the same as solving 8x- 2= 10. The two values where that is equal to 10 separate where it is <10 and > 10. Check one point in each of the three intervals to see which is which.
For the inequality | -8x - 2| = 10, its best to divide it into 2 cases; for all x values such that -8x - 2 > 0 (a) and all x values such that -8x - 2 < 0 (b). This step eliminates the use of absolute value functions.
For all x (a), the absolute value function would disappear (because -8x - 2 will always
be greater than 0 for all x (a) values).
For all x (b), you would replace the absolute signs wiht a negative out infront (because -8x - 2 will always be less then 0).
So you would have -8x - 2 > 10 and -(-8x - 2) > 10 for two of the cases. (and these 2 cases would give you the union of pair intervals).
NOTE!: You must go back and check your domains to see if your values are consitent with the orignal problem. This is a common mistake.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
