Quadratic functions: [Diagram Included] Football game scenario
The discussion revolves around a football game scenario involving a quarterback who must throw a ball over an opposing player to reach an open receiver. The quarterback's height is assumed to be 150 cm, and the ball must be thrown 1.5 m above the height of the opposing player, who is 190 cm tall. Participants suggest breaking down the motion into horizontal and vertical components to derive the equation for the ball's path. The receiver, positioned 9.5 m away, can move within 2 m of his initial location to catch the ball. Ultimately, the conclusion is that the receiver can catch the ball, thereby winning the game.
Swan
You are the quarterback for the Quinte Saints Football team. You are in the middle of the COSSA gold medal game and you see your receiver is wide open down the field beside the sideline. If he catches the ball, you win the game. However, the biggest guy Joey from the opposing team who is 190 cm tall is running towards you. You decide to throw the ball so that the highest part of the path is 1.5 m over Joey's head to avoid him reaching it if he jumps. You throw the ball at your receiver releasing the football at your head level when Joey is 5 m away from you.
The goal of this task is to figure out if your teammate can catch the ball and win the game.
Assumption variable: Your Height (to the nearest centimeter): 150 cm. **NOTE**: We had to assume what the quarterback's height was and in this my height is 150 cm.
a) Draw a sketch of the situation including the path of the ball (assume no wind). Fill in all information you know at this time.​
b) Determine the equation representing the path of the football.​
c) Your receivers typically catch the ball 1 m from the ground. If your player is 9.5 m away, and can run within 2 m of his initial location to catch the ball, does he catch the ball to win the game? Justify.​
None
a)
b) I have no idea how to go about this.​
c) I say he would catch the ball to win the game because the receiver can cover 2 m of horizontal distance if needed.​
Ok for a) (even if you could be a little clearer and for example show the difference in height of Joey, you and the fact that the receiver capture the ball at 1m height).
As for b), decompose the motion in an horizontal one (x(t), given by a usual uniform rectilinear motion) and a vertical one (y(t), uniformly accelerated motion in the gravity field). Then solve y(x) and you have the equation for the path.
Finally for c) using the path just found, check at what distance the ball fall from the receiver and you're done
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
