Quantization Postulates for a Particle
kilojoules
Show that the operators x^2 p_x^2+p_x^2 x^2 and 〖 (xp_x+p_x x)〗^2/2 differ only by terms of order ℏ^2.
The attempt at a solution is attached (Postulates.pdf)
I don't know what you are trying to do in your solution ,you should explain it better. The first line equality is not correct,keep in mind that x,p momentum do not commute. I suggest expanding the second term first and see how it differs from the first.
I first found the quantum mechanical operator corresponding to the classical quantities xP_x, and according to the information I found on a downloaded file ("Dry2ans.pdf"), can't remember the source, I found that:
xP_x → xP_x + P_x x
As per your suggestion, bp_psy, I don't know which second term you are talking about. Is it of the first expansion or which one?
You initial post does not say that x,p_x are classical observables but operators.Which one is it?
The classical observable xp_x is represented by hermitian operator \hat{x}\hat{p}_{x}+\hat{p}_{x} \hat{x} as they say in that document but the operator \hat{x}\hat{p}_{x} is very different from \hat{x}\hat{p}_{x}+\hat{p}_{x}\hat{x}. Sometime people do not hat their operators so you shouldn't always assume that no hats mean classical observables.
What I meant by the second term is \frac{(\hat{x}\hat{p}_{x}+\hat{p}_{x}\hat{x})^2}{2}.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
