Quantum - determine reflection coefficient
wood
I am working through a past exam paper and this one has me stumped
1. Homework Statement
Consider a particle of mass m with kinetic energy E incident from the left upon a
step-up potential:
$$U(x)=\begin{cases} 0 & \quad \text{for } x <0\\ V & \quad \text{for } x>0\\ \end{cases} $$
assuming V > 0. Assume that E > V .
(a) For the two distinct regions, write down the relevant time-independent Schrodinger ¨
equation in the form
$$\frac{d^2\psi}{dx^2}=-k^2\psi$$where k is real. Clearly specify the values of k^2 in each region, using kL to
represent the value of k to the left of the step, and kR to represent the value of k to
the right of the step. For each case, write down the general solution of the
Schrodinger equation in terms of real or complex exponentials.
(b) Impose the relevant boundary conditions for this system.
(c) Solve your boundary conditions to show that the reflection coefficient is given by
$$R=\left(\frac{k_R-k_L}{k_R+k_L}\right)^2$$
[3]
(d) Obtain a formula for the transmission coefficient. How does it differ from that
obtained in the classical case?
TISE and ##R=|\frac{B}{A}|^2##
[/B]
So I can get my equations for part a
$$\psi_L(x)=Ae^{ik_Lx}+Be^{-ik_Lx}$$
$$\psi_L(x)=Ce^{ik_Lx}+De^{-ik_Lx}$$
D=0 as there is no reflected wave on x>0 so
$$\psi_L(x)=Ce^ik_Lx$$
and impose the boundary conditions at x=0 for part be and get
$$\psi_L(0)=\psi_R(0) $$
$$A+B=C$$
and
$$\psi'_L(0)=\psi'_R(0) $$
$$ik_L(A-B)=ik_RC$$
$$ C=\frac{k_L(A-B)}{k_R}=A+B$$
And this is where it all goes wrong. I cannot get from there to $$\frac{B}{A}=\left(\frac{k_R-k_L}{k_R+k_L}\right)$$
I end up with ## \left(\frac{k_L-k_R}{k_R+k_L}\right)## when I try to compute B/A. Is there another way to solve the boundary conditions for the reflection coefficient that gets the correct answer?
Thanks
You did get the correct answer ...
No, I keep getting kL-kR when I try to solve for A and B algebraically.
What happens when you square a negative number?
I get a positive number so I thnk I might be an idiot and have had the correct answer all along...ie
$$\left(\frac{k_R-k_L}{k_R+k_L}\right)^2=\left(\frac{k_L-k_R}{k_R+k_L}\right)^2$$
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
