How Does Quantum Mechanics Describe Particle Dynamics in Spherical Coordinates?
  • Thread starter Thread starter unscientific
    Energy Quantum
The discussion focuses on solving a quantum mechanics problem involving particle dynamics in spherical coordinates. Participants work through various parts of the problem, including expressing momentum in terms of spherical coordinates and demonstrating relationships between position and momentum operators. Key points include the use of Einstein notation, commutation relations, and operator algebra to derive results for parts (a) through (d). There are corrections and suggestions for improving the approach to solving the problem, emphasizing the importance of treating operators correctly rather than as simple functions. The conversation highlights the complexity of quantum mechanics and the need for careful mathematical manipulation.
unscientific
Part (a): By writing L2 in einstein notation, show that p2 can be written as:
Part(b): Show ##\vec{p}.\hat {\vec{r}} - \hat {\vec{r}}.\vec{p} = -2i\hbar\frac{1}{r}##
Part(c): Show ##\vec{r}.\vec{p} = rp_r + i\hbar##
Part (d): Show ##p^2 = p_r^2 + \frac{L}{r^2}##
I missed out terms in part (a), I couldn't get parts (b) and (c) of this question.
Part (a)
L^2 = \epsilon_{ijk}x_j p_k \epsilon_{ilm} x_l p_m
= \epsilon_{ijk}\epsilon{ilm} x_j p_k x_l p_m
= \left(\delta_{jl}\delta_{km} - \delta_{jm}\delta_{kl}\right)x_jp_kx_lp_m
= x_jp_kx_jp_k - x_jp_kx_kp_j
= x_j^2p_k^2 - x_jp_jp_kx_k
= r^2p^2 - (\vec{r} . \vec {p})
Part(b)
\vec{p}.\hat {\vec{r}} - \hat {\vec{r}}.\vec{p} = -i\hbar\left(\nabla . (\frac{\vec{r}}{r})\right) + i\hbar\left(\frac{\vec{r}}{r}.\nabla\right)
Now using product rule:
= -i\hbar\left[ \vec{r}.(\nabla \frac{1}{r}) + \frac{1}{r}\nabla . \vec{r}\right] + i\hbar\left[\frac{1}{r} \vec{r}.\nabla\right]
Now, ##\nabla \frac{1}{r} = -\frac{1}{r^3}\vec{r}## and ##\nabla . \vec{r} = 3##. Using these results, we obtain:
= \frac{i\hbar}{r}
Part (c)
Using result of part (b):
\vec{r}.\vec{p} = 2i\hbar + r(\vec{p}.\hat{\vec{r}})
= 2i\hbar + \vec{p}.\vec{r}
= 2i\hbar -i\hbar\nabla . \vec{r}
= 2i\hbar - 3i\hbar
= -i\hbar
Part(d)
Chuck parts (b) and (c) into the equation and you get the answer.
The physical interpretation is:
Total Energy = Radial Kinetic Energy + Rotational Energy
For part (a), I think you made a mistake on the 5th line. You aren't allowed to just swap the order of x's and p's.
for part b, try acting with the difference on a function...and avoid playing algebraically just with the operators alone...
For example after using the chain rule, you would cancel out terms with having a function being acted on...
OK here's what I got:
Now i change ##p_k## in first and second term to ##-i\hbar\partial_k##:
-i\hbar x_j\partial_k(x_jp_k) +i\hbar x_j\partial_k(x_kp_j)
Using product rule: ##\partial_kx_j = \delta_{kj}##
i\hbar \left[-x_jp_k\delta_{kj} - x_j^2\partial_kp_k + x_jp_j + x_jx_k\partial_kp_j\right]
Converting ##\partial_k = \frac{i}{\hbar}p_k##:
i\hbar \left[ -x_jp_j - \frac{i}{\hbar} x_j^2p_k^2 + x_jp_j +\frac{i}{\hbar}x_jx_kp_kp_j\right]
you should use the commutation relations for exchanging the x and p's...So in general:
p_{i} x_{j}= -i \hbar δ_{ij} + x_{j} p_{i}
it's still not trivial to write the momentum as the derivative and making it act on x alone... you are still having operators and as such they act on functions ... I'll repeat, avoid treating them as functions alone and work algebraically so "free".
For example take the commutator of p and x:
[p_{i},x_{j}] = p_{i}x_{j} - x_{j} p_{i} = -i\hbar δ_{ij} + x_{j} i\hbar \frac{d}{dx_{i}}
is not correct
Instead you take:
[p_{i},x_{j}] f= p_{i}x_{j}f - x_{j} p_{i}f= -i\hbar \frac{d}{dx_{i}}(x_{j}f)+ i\hbar x_{j} \frac{d}{dx_{i}}f = -i\hbar δ_{ij} f
so you take
[p_{i},x_{j}]= p_{i}x_{j} - x_{j} p_{i} =-i\hbar δ_{ij}
p_{i} x_{j}= i \hbar δ_{ij} + x_{j} p_{i}
(I may forget a - in front of i \hbar )
That's exactly the relation I was looking for. thanks alot
:smile: it's basic (before the central potential you are trying to work with)
We need to show this: ##x_j^2p_k^2 - (x_jp_j)(x_kp_k) +i\hbar(x_jp_j)##
Starting:
Using ##[x_i,p_j] = x_ip_j - p_jx_i = i\hbar \delta_{ij}##:
x_j(x_jp_k - i\hbar \delta_{jk})p_k - x_j(x_kp_k - i\hbar)p_j
x_j^2p_k^2 - i\hbar x_jp_j - x_j(x_kp_k)p_j + i\hbar x_jp_j
Using ##[x_kp_k,p_j] = x_kp_kp_j - p_jx_kp_k = i\hbar \delta_{jk}p_k##
= x_j^2p_k^2 - i\hbar x_jp_j - x_j(i\hbar\delta_{jk}p_k + p_jx_kp_k) + i\hbar x_jp_j
= x_j^2p_k^2 - i\hbar x_jp_j - x_jp_jx_kp_k
= r^2p^2 - i\hbar (\vec{r}.\vec{p}) - (\vec{r}.\vec{p})(\vec{r}.\vec{p})
which is different from the answer..
bumpp
bumppp
bumpp
