Quantum Entangled Emitter and Receiver
Antim@tter
Hello fellow science enthusiasts.
The other day I was thinking of a device for instantaneous transfer of data. You would have two entangled particles (or any even number but two just for simplicity), then you would "put" each one in two devices. An input is needed. For example a simple message in binary saying "Test 123". The message would be indeed made up of ones and zeros. That would be then recognised by another device as each 1 or 0 is an instruction. For example a one would turn on a magnetic field to rotate the particle so it is pointing up and a 0 pointing down with a neutral state or rest position being pointing to the middle. Now I know up, down and middle are not specific directions but just imagine them as relative ones. If I am correct that would mean the other particle would experience the same effect and the up or down will be detected by a device with exact recognition of what each state is and it would translated into ones and zeros. That would then be put together to form a bunch of ones and zeros which would go into a output of some sort which will then translate the binary into "Test 123". This is just to begin with, you could speed up the process with more data being sent to maybe even form a picture and later on, a live video feed.
Now I know this is all just something I thought about which will at least, have some problems to begin with. To start, I don't even know if it's actually possible to use a small magnetic field on an entangled particle without disrupting the entanglement, in other words, breaking the bond. I just wanted to know if it's possible. If it was, it could mean a communication latency would be very little (even on an interstellar or intergalactic scale)
Many thanks,
A Science Enthusiast
Sorry - entanglement doesn't work that way.
No matter what you do to your particle, if the other guy makes either a left-right or an up-down measurement, he'll get a random bit.
There's no way of even discovering that any entanglement was going on until you and the other guy get together and compare notes. Then you'll discover that, for every particle pair, if you had both measured up-down or you both had measured left-right you always got opposite answers; if one of you measured left-right and the other up-down the results were completely uncorrelated.
Thanks for clearing up the confusion :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
11K
