Quantum Queries on the Harmonic Oscillator
T-7
Hi folks,
I wonder if I could run a few things past the quantum gurus among you - I'm just not quite convinced of some of the results I've been deriving.
Consider the ground state of the simple harmonic oscillator at t = 0 with the normalised wave function \sqrt[4]{\frac{m\omega}{\pi\hbar}}e^{-\frac{m\omega}{2\hbar} x^2}.
If the position uncertainty is defined as \Delta x = \sqrt{<\widehat{x}^{2}>-<\widehat{x}>^{2}} and the momentum uncertainty as \Delta p = \sqrt{<\widehat{p}^{2}>-<\widehat{p}>^{2}}, determine the product \Delta x . \Delta p. Comment on the result.
I begin by observing that <\widehat{x}> and <\widehat{p}> are both zero, by symmetry arguments. Thus \Delta x = \sqrt{<\widehat{x}^{2}>} and \Delta p = \sqrt{<\widehat{p}^{2}>}.
I go on to calculate <\widehat{x}^{2}> and <\widehat{p}^{2}>.
I find that <\widehat{x}^{2}> = \frac{\hbar}{2m\omega}, a result I am pretty confident of (it was an easy integration).
My queries arise for <\widehat{p}^{2}>, which comes out as \hbar(m\omega - \frac{1}{2}), giving \Delta x . \Delta p = \sqrt{\frac{\hbar}{2m\omega}} . \sqrt{\hbar(m\omega - \frac{1}{2})} = \hbar\sqrt{1/2 - 1/4m\omega} - not a very "nice" result. I'm suspicious.
I make <\widehat{p}^{2}> to be
<\widehat{p}^{2}> = \sqrt{\frac{m\omega}{\pi\hbar}}\int^{+\infty}_{-\infty} e^{-\frac{m\omega}{2\hbar} x^2}.(-\hbar^{2}\frac{\partial^2}{\partial x^2}).(e^{-\frac{m\omega}{2\hbar} x^2}) dx = . . . = \sqrt{m^{3}\omega^{3}\hbar/\pi}.I_{2} - \sqrt{m^{3}\omega^{3}/\pi\hbar}.I_{1}
as
(\frac{\partial^2}{\partial x^2}).(e^{-\frac{m\omega}{2\hbar} x^2}) = ... = -\frac{m\omega}{\hbar}.e^{-m\omega x^2/2\hbar} + (\frac{m\omega}{\hbar})^2.x^2.e^{-m\omega x^2/2\hbar},
where
I_{1} = \int^{+\infty}_{-\infty}x^2.e^{-m\omega x^2/\hbar} dx = ... = \sqrt{\frac{\pi\hbar^{3}}{4m^{3}\omega^{3}}}
I_{2} = \int^{+\infty}_{-\infty}e^{-m\omega x^2/\hbar} dx = ... = \sqrt{\frac{\pi\hbar}{m\omega}}
etc.
determining finally that \hbar(m\omega - \frac{1}{2})
Has something gone wrong here, perhaps, or should I just accept the result?
Cheers!
T-7 said:
Hi folks,
there is something wrong here. Look below at your second derivative of x^2 times the exponential. The two terms you get from the second derivative have a relative factor of m omega/ hbar. and yet in the above expression th erelative factor is not m omega/hbar. Check that equation.
as
where
etc.
Cheers!
You are right. The expression should have read:
<\widehat{p}^{2}> = \sqrt{\frac{m\omega}{\pi\hbar}}\int^{+\infty}_{-\infty} e^{-\frac{m\omega}{2\hbar} x^2}.(-\hbar^{2}\frac{\partial^2}{\partial x^2}).(e^{-\frac{m\omega}{2\hbar} x^2}) dx = . . . = \sqrt{m^{3}\omega^{3}\hbar/\pi}.I_{2} - \sqrt{m^{5}\omega^{5}/\pi\hbar}.I_{1}
This eventually leads to \hbar m\omega / 2, and then we do indeed derive Heisenberg's uncertainty relation in the form \hbar / 2
Many thanks.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
