Quantum Tunneling Wave Packets: Explained
The discussion revolves around the interpretation of wave packets and wave functions in the context of quantum tunneling. Participants explore the implications of these concepts on particle behavior, wave-particle duality, and the nature of measurements in quantum mechanics.
  • Some participants express confusion about the wave function being a probability density function, suggesting that it leads to paradoxical implications regarding particle behavior during quantum tunneling.
  • One participant clarifies that the wave function itself is not the probability density function; rather, it is the square of the wave function that represents probability density.
  • There is a discussion about how the wave function differs for various particles, with distinctions made between bosons and fermions based on symmetry properties.
  • Some participants propose that the wave function collapse upon measurement results in a definite location for the particle, while others question the implications of this collapse on the interpretation of quantum mechanics.
  • One participant suggests that particles may be viewed as illusory phenomena created by wave packets, challenging the notion of particles as fundamental entities with unique wave functions.
  • Another participant raises the possibility of measuring particles on both sides of a barrier to test different interpretations of quantum tunneling.
  • There is a mention of the Hamiltonian's role in coupling states and how this could lead to different energy eigenstates affecting particle behavior.
Participants express differing interpretations of the wave function and its implications for quantum tunneling, with no consensus reached on the nature of particles and wave-particle duality. The discussion remains unresolved with multiple competing views presented.
Limitations include the dependence on interpretations of the wave function and the implications of measurement, as well as the complexity of representing particles in quantum mechanics. The discussion highlights the unresolved nature of these concepts in the context of quantum tunneling.
  • #31
f95toli said:
Couldn't tunneling of states (as opposed to particles), which after all is more general, by viewed as evidence of this?
There are a few well-known systems (a Josephson junction would be one example) where the system is initially trapped in an insulated potential well but can tunnel from this (nearly) dissipationless state to a dissipative state where the system is subject to very rapid decoherence (and is therefore "measured"). This system has e.g. been used as a qubit.
As far as I know no one has ever observed a situation where the systems BOTH stays in the non-dissipative state AND stays in the well.
I'm sorry, but I'm not able to comment on your example.
  • #33
That is a shame, because it it is a good example:smile:
But the basic idea is quite simple.
Imagine a particle trapped in a well, to the left there is an infinite wall; to the right a barrier with some finite height (meaning there is a non-zero tunneling probability). Hence, to start with we have a "particle in a box" situation, the wavefunction is localized to the well,
Now, in addition to this we assume that if the particle leaves the well by tunneling to the right it goes into a state with a lot of dissipation; i.e. it becomes a "classical particle" and is instantly "measured".
Now, this turns out to be a good description of several REAL systems and has been studied experimentally for over 25 years (there are whole books about this, see e.g. Takagi's "Macroscopic Quantum Tunneling" which is slightly odd in places, but otherwise quite good).
The reason why I thought this might be a good example is that the tunneling is a very well defined process; in some of these systems it is quite literally a SINGLE state (described by a single-particle wavefunction) that tunnels (as opposed to ensembles of particles and other messy situations) which in turn means that it is an ideal "toy system"; both theoretically and experimentally (and the experimental date agree very well with theory).
  • #34
I'm sure it is and I appreciate your elaboration on it. I hope you don't think the idea of tunneling itself was in question, by the way. These discussions have a way of going off in a hundred different directions. And they often end with someone weighing in with the important revelation that "quantum mechanics is the most accurate theory ever devised by man".
I still think the OP had a reasonable question in terms of what kind of experimental verification could be done for the oft-cited thought experiment in question. I'm reluctant to get any further into the correspondence because it seems to have taken a vaguely unpleasant turn.
  • #35
jambaugh said:
You can't separate these issues. Via CI the wave function is a theoretical construct used to describe the behavior of the physical particle. In short we don't measure wave functions they are not observable. In CI they are not physical. In other interpretations they are given different ontological status but are none-the-less still not observable.
In this case, the question has a physical meaning and so the question can be answered via direct measurements without resorting to wave packet theory. ie, take a closed system containing a barrier and a free particle. Fire the free particle at the barrier with no holes, then put a detect on both sides of the barrier. If a particle is detected on both sides of the barrier, then this proves that a particle can split itself into non-entangled reflected and transmitted particles via quantum tunneling, which effectively answers the original question without resorting to wave theory
  • #36
This has been done already. The double-slit experiment is not much different from the passage of a particle through a barrier. The details vary, but you are still dealing with the same wave interference effect. I think it is well established that particles do not "split" in the double slit setup, so there is no reason to believe that they would "split" in the barrier setup.
  • #37
No. Not even close to the same thing...and there is no interference effect. The double slit experiment tests wave interference and is done at a scale that assumes tunneling is negligible...whereas this would be done on a much smaller scale to test tunneling and there are no interference effects...have you been following this discussion at all?
  • #38
Against my better judgement, I keep trying to figure out what the heck we're talking about here. I get the impression that junglebeast makes a qualitative distinction between a wave function that is physically spread out versus one that is actually detached from itself. I have my doubts that this is really a significant distinction: the same mathematics creates these cases so they ought to follow the same physics. I also sympathize with those posters who have offered other physical systems as evidence of something or other...the probelm is, just what point is being made? Feynman once said that all of the mysteries of quantum mechanics are contained in the double slit experiment, but I think people have taken that too literally.
When junglebeast talks about a particle splitting in two at the barrier, I don't know what to make of that. But if he's just asking for experimental proof that the two branches of his wave function cannot be simultaneously detected, I think he hasn't been answered yet. The Josephson junction example might in fact be pertinent, even more so than the double slit, but can we first decide whether the experiment can be done more or less directly?
  • #39
Because I think there is a far more simple representation for the mathematics of QM, which also has much more sensible meaningful interpretation than the attempted "Copenhagen interpretations," and one of the only places its predictions differs from the overly complicated existing theory is in this specific case. So if this specific case has no experimental evidence to support the current model, then I would be more inclined to believe the more simple model, which does comply with all the other QM experiments I know of.
  • #40
I've briefly googled ftl tunneling and it appears possible but doesn't tunneling end up with a lower energy state after crossing the barrier? So if the barrier is c wouldn't the energy of the particle be greater after crossing c or does the wavelength of the photon lower itself enough to satisfy the tunneling rules and yet still be ftl because the energy of the photon is greater than usual for the wavelength it dropped to?
Frank
  • #41
what in god's name is going on in here. has anyone in here actually taken a qm class?
junglebeast said:
Thank you conway for trying to stay on track with my original question. However you are not asking the same question I was asking anymore.
This is a rendering of the wave function being partially reflected and transmitted through a barrier:
An initial wave function, call it W, is split into 2 separate wave functions call them Wa and Wb, one of which is transmitted and the other reflected.
Case A: Wa and Wb can be treated as separate wave functions; it is possible for Wa to collapse and it does NOT cause collapse of Wb.
Case B: When Wa collapses, Wb simultaneously collapses because they are really still part of the same wave function, regardless of their spatial separation.
The wording on wikipedia's page seems to indicate support for Case A. So far I have only seen support for case B in the replies to this thread.
My question: is there any specific evidence or experiment (as opposed to simply quoting theory) supporting one case over the other?
the answer is resoundingly B. you've asked it twice already. it is always B. in fact there are actually 3 "parts" to the wavefunction because there's the nonzero probability of the particle being in the barrier!
jambaugh has told you already twice. the point of collapse is not that the wavefunction goes to zero everywhere. the point is that it peaks around your measurement. note that i say peaks and not dirac deltas since the probability of a particle being a point [itex]x_0[/itex] in space is zero:
[tex]\int_{x_0}^{x_0}\psi^2 dx = 0[/tex]
so the wavefunction peaks/collapses/updates and then spreads out again after sometime ( unless it's in a coherent state, which it's not in this case ).
you need to look at what a wavefunction really is: a solution to a pde whose square is a probability distribution function. stop playing these metaphysics games.
  • #42
jambaugh has told you already twice. the point of collapse ...
...you need to look at what a wavefunction really is: a solution to a pde whose square is a probability distribution function. stop playing these metaphysics games.
Again, that wasn't his question. We know the "correct" answer is B. His question: what is the direct experimental evidence?
  • #43
The fact that you observe only one particle after the fact! But again you don't observe wave-functions they are the mathematical description not something experimentally observed. The issue is what is the correct formal mathematical description and the answer is: we are here talking about a single system with its single wave-function.
Now to understand it better we should consider how the logic parses through the quantum description. The two pieces of wave-function in this example are formally added together:
[tex]\psi(x) = \psi_L(x) + \psi_R(x)[/tex]
This superposition is simply the resolution of a single vector in terms of two components, like
v = xi + yj. Underlying this vector sum is a tensor sum of spaces spanned by the components. The logical analogue of the tensor sum in QM is the logical or. In this case we are resolving the superposition of components into "the particle reflected or it tunneled". Note the coherent sum is not the 'or' operation but rather reflects the fact that the two component descriptions are both "off a bit". Superposition is a property of our description not of the system itself. It reflects our "poor" choice of basis in describing a system.
Compare all this to the tensor product of two system descriptions. This is what we're thinking when we talk of "two wave-functions" instead of "two pieces of a single wave-function". The tensor sum of two modes corresponds somewhat to the compositional "and".
[tex]\Psi = \psi_1\otimes \psi_2[/tex]
reflects a logical statement system 1 was observed to correspond to mode [itex]\psi_1[/itex] and system 2 was observed to correspond to mode [itex]\psi_2[/itex].
When we take the product of spaces we are composing separate systems to treat them as a single composite system. (It is in this case were we may invoke entanglement.) We again get a single "wave-function" but it will be a function of two independent position parameters corresponding to classical configurations of two component systems e.g. two separate electrons (or more properly to positions of two separate system-detection events).
This is not the correct interpretation of the case being discussed here.
In vernacular language we distinguish these two cases by the correspondence "two wave-functions" = tensor product of two wave functions= composite system, and "two components of a single wave function" = superposition = coherent sum of two modes for a single system.
  • · Replies 18 ·
  • · Replies 36 ·
10K
  • · Replies 32 ·
