Quaternionic powers of quaternions?
  • Context: Graduate
  • Thread starter Thread starter Aphex_Twin
    Quaternions
The discussion revolves around the concept of defining quaternionic powers of quaternions, exploring the mathematical framework and challenges involved in extending the notion of complex powers to quaternions. Participants examine the implications of non-commutative multiplication and the potential for defining powers using exponential and logarithmic functions.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants inquire whether quaternionic powers can be defined similarly to complex powers, referencing the use of exponential and logarithmic functions.
  • Others argue that the non-commutative nature of quaternion multiplication complicates the application of power series and may lead to contradictions.
  • A participant suggests that defining powers using polar forms and Cartesian coordinates could yield different results based on the representation chosen, raising concerns about the well-defined nature of the operations.
  • Some participants discuss the need for unique representations of quaternions and the implications of branch cuts in defining logarithmic and exponential functions.
  • There is mention of specific examples, such as calculating powers of the imaginary unit i, which demonstrate the potential for different outcomes based on the chosen polar forms.
  • A later reply introduces the idea that any reasonable extension of logarithmic and exponential functions to quaternions may imply commutativity, which is seen as problematic.
Participants express differing views on the feasibility and implications of defining quaternionic powers. There is no consensus on whether such definitions can be made without contradictions, and multiple competing perspectives on the approach to take remain evident throughout the discussion.
Limitations include the dependence on the choice of representation for quaternions, the multivalued nature of the logarithmic and angular functions, and unresolved issues regarding the convergence and geometric properties of quaternion operations.
Aphex_Twin
Can such things be defined?
I know there are complex powers to complex numbers (using polar forms), but what about quaternions (or perhaps complex powers of quaternions...).
Any ideas?
Mathematics news on Phys.org
Well, the complex powers are defined by exp and log, and these in turn have power series expansions, so one may be able to apply them to quaternions, however, multiplication isn't commutative, so the sums are going to be slightly odd to work out.
A little something more concrete?
Like what? Fractional, irrational, and complex powers are defined with exp and log which are defined as power series for the real numbers (for those numbers possesing a valid log expansion, obviously - what are you going to replace Arg with?), for heaven's sake, so how can a generalization to some other non-commutative ring possibly be more concrete? Some particular numbers may have nice exponentiation relations, eg i^i=-1, but even in the complex numbers, most do not (what is sqrt(2) ^(sqrt(5)-isqrt(3))?)
It's just a formal definition, it may not even make sense - after all, in what topology are you considering convergence issues?
Maybe he meant "concrete",as in the relative of "cement"?
Daniel.
Please, be gentle, I am not a math guru and I'm not familiar with power series. So if you can spell it out in more layman's terms? ;)
Power series aka mclaurin or taylor series. (not a guru topic: taught in high school in the UK, or it used to be), but a simple way of trying to work out what f(x) is for some x, and some function.
[tex]e^x = \sum_{r=0}^{\infty} \frac{x^r}{r!}[/tex]
is the definition (strictly speaking, one of them) of e^x.
log(x) is the inverse function (thought of as e^x a function from R to R^+) there are various ways of working out log(y) in terms of power series too (that is polynomials in y)
x^r is defined to be
[tex]e^{rlogx}[/tex]
e, or exp has a nice obvious continuation to the complex numbers, log doesn't have such a good extension (it is a "many valued function")
some times, in some cases you may find x^y for complex arguments in nice ways, but not always. So surely you'd be better off finding out what the complex version of your question is before thinking about the quarternionic one.
Ah, yes, Taylor ;) English is not my first language so I don't know all Math English names. Though Taylor is not my strong point.
I already figured out p^q where p and q are complex. It goes something like this:
I write the first in polar form and the second in cartesian form:
p=r*e^i*t
q=a+b*i
p^q = (r*e^i*t)^(a+b*i) = r^(a+b*i) * e^[i*t*(a+b*i)]
r^(a+b*i) = r^a * r^(b*i) = r^a * e^[b*i*ln(r)]
e^[i*t*(a+b*i)] = e^(i*t*a+i*t*b*i) = e^(i*t*a-t*b)
p^q = r^a * e^[i*b*ln(r)]*e^(i*t*a) * e^(-t*b) = r^a/(e^t*b) * e^[i*b*ln(r)]*e^(i*t*a) ...
And it boils down to multiplying complex numbers.
How do you do this with quaternions?
you need to show that that is well-defined and leads to no contradictions first, that is that it is independent of the representation of p and q that you've chosen. (if i replace t by t+2pi then what happens?) Moreover, if I take p=1 and choose t to be 2pi, and raise to the power sqrt(2) I get an complex number with strictly nonzero imaginary part. is that right?
then you'd have to decide if the quarternions have a nice choice of r, theta style norm and argument. They are a 2-d vector space over C for instance. But you'd also need to check that algebraic operations on H, have a nice reflection in the geometric properties of this vector space.
Am I missing something here?
Let's consider p = q = i as an example.
There are lots of ways to wrote p in polar form. Two examples are:
i = 1 * e^(1/2 pi i)
i = 1 * e^(5/2 pi i)
Now, if we apply your method, using the first polar form we get:
i^i = 1^i * e^((1/2) pi i * i)
= e^(i ln 1) * e^(-pi/2)
= e^0 * e^(-pi/2)
= e^(-pi/2)
Using the second form,
i^i = 1^i * e^((5/2) pi i * i)
= e^(i ln 1) * e^(-5pi/2)
= e^0 * e^(-5pi/2)
= e^(-5pi/2)
Which are clearly different numbers. The problem here is that your procedure is not well-defined. That means that when given two different representations of the same number, your method gives two different results.
Just looking at the end result, Quaternions raise another problem -- their addition is commutative, but their multiplication is not. So, if we naively try to apply the identities for log and exp:
a * b = e^(ln a) * e^(ln b) = e^(ln a + ln b) = e^(ln b + ln a) = e^(ln b) * e^(ln a) = b * a
Which "proves" that multiplication is commutative... but we know multiplication is not, which is a contradiction.
What if I make r and t dependent on a c and d, where p=c+d*i
r = |p| = sqrt(c^2 + d^2)
t = arg (p) = atan(d/c)
This way there is a unique representation. I'm looking more into it...
I was also looking at the formula here:
http://mathworld.wolfram.com/ComplexExponentiation.html
And trying to figure it out (without success thus far).
I see u have lost connection with the quaternions.You're speaking about old,rusty complex numbers...
What do you mean unique representation??
You mean from
[tex]p=c+id \Rightarrow p=re^{it}[/tex] through a one to one mapping (understood in terms of pairs/elements of R^{2}) ??If so,think again and use the famous formula due to Leonhard Euler.
Daniel.
Technically, that is not true. arg and atan are multivalued functions. To get a unique representation, you have to make an (arbitrary) choice of a branch cut. There is a standard choice of branch cut that we denote Arg and Atan, which does give a unique representation (called the principal value)
Alright, I'm getting it. I presume there are more such "branch cuts" to be made when talking of quaternionic powers of quaternions.
This means for quaternions I can use the formula for complex exponentiation, replace the real numbers with complex numbers (chosing an appropriate norm and atan representations) and make more restrictions. I'll see what I can get.
I think Hurkyl's proof that any reasonalbe extension of log and exp implies the quartenions are commutative ought to be the final nail in the coffin, don't you?
9K
  • · Replies 56 ·
