Solve the Pi (y/2π)² = y²/4π Mystery
  • Thread starter Thread starter powp
The equation pi(y/2pi)² = y²/4pi simplifies through algebraic manipulation. By substituting and rearranging, it shows that pi cancels out from the numerator and denominator. The key steps involve recognizing that (y/2pi)² can be expressed as y²/(4pi²). This leads to the conclusion that the left side equals the right side when simplified correctly. The discussion clarifies the cancellation process, confirming the equality holds true.
powp
How does pi(y/2pi)^2 = y^2/4pi?
I am confussed.
Thanks
Mathematics news on Phys.org
\pi \left(\frac {y} {2\pi}\right)^2 = \frac {\pi y^2} {(2\pi)^2} = \frac{\pi y^2} {4\pi^2} = \frac {y^2} {4\pi}
In short and abstract form
\left(\frac{a}{b}\right)^{2}=\frac{a^{2}}{b^{2}}
and
\left(ab\right)^{2}=a^{2}b^{2}
,okay?
Daniel.
what happens to the pi on top?
It cancels with one of the pi's on the bottom.
\frac{\pi y^2} {4\pi^2} = \frac{\pi y^2} {4\pi*\pi} = \frac{\pi(y^2)}{\pi(4\pi)}
Do you see how you can cancel?
Yes Thanks
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
