Questing about eigenvector order
  • Thread starter Thread starter 939
    Eigenvector
The discussion focuses on the order of eigenvectors, specifically why the solution (1, -8) is preferred over (-8, 1) in a given equation. The equation derived from the matrix multiplication indicates that only (1, -8) satisfies the condition for being an eigenvector, while (-8, 1) does not yield a zero vector when substituted. It is emphasized that there are infinitely many scalar multiples of eigenvectors, making the choice of representation arbitrary. The importance of maintaining the correct order in eigenvectors is highlighted, as they are not merely two numbers but ordered pairs. Ultimately, the correct eigenvector representation is crucial for accurate mathematical interpretation.
The equation he obtains is
\left( \begin{array}{cc} 8 & 1 \\ -8 & -1 \end{array} \right) \left( \begin{array}{c} x \\ y \end{array} \right) = 0
##(x,y) = (1, -8)## is a solution, but not ##(x,y) = (-8, 1)##. Try it for yourself: substitue the possible solutions in the above equation, and see what works.
By the way, there is an infinite number of possible solutions: any vector ##a (1, -8)## is also a solution (with ##a## a scalar). Which one to choose is arbitrary. In the video, he could have chosen ##y=1## instead, and found ##(x,y) = (-1/8, 1)## (you can check for yourself that solution also).
Likes 1 person
You talk here, and in a similar question in the homework section as if the "eigenvector" were just two numbers in arbitrary order. It is not- it is a vector which, in this case, can be represented[/b] as an ordered pair of numbers.
You should, yourself, have done the multiplication
\begin{pmatrix}8 & 1 \\ -8 & -1\end{pmatrix}\begin{pmatrix}-8 \\ 1\end{pmatrix}= \begin{pmatrix}-64+ 1 \\ 64- 1\end{pmatrix}= \begin{pmatrix}-63 \\ 63\end{pmatrix}
which is NOT
0\begin{pmatrix}-8 \\ 1 \end{pmatrix}
Likes 1 person
  • · Replies 16 ·
