I Question about an interesting experiment video (two magnetic balls in tubes)
  • I
  • Thread starter Thread starter Swamp Thing
    Experiment
In the discussed video, two magnetic balls in vertical tubes roll upwards when the tubes are rotated, raising questions about their behavior at height h. When the tubes slow down, it's debated whether the balls will stop or roll down, potentially reversing the tube's rotation. The phenomenon is also linked to philosophical discussions about time's arrow, with comparisons made to one-way valves and ratchets that indicate time direction. Additionally, the role of inertia and friction in the balls' movement and alignment is examined, suggesting that initial conditions significantly affect their vertical velocity. Overall, the discussion explores the complex interactions between motion, magnetic forces, and philosophical implications of the experiment.
Swamp Thing
Insights Author
In this video...
https://www.physicsforums.com/media/magic-magnetic-balls-defy-physics.6951/
... a pair of magnetic balls in two vertical tubes, roll upwards when the tubes are rotated, irrespective of the direction you rotate them in.
A couple of questions...
[1] Say the tubes are mounted on nearly ideal bearings. We give them a little spin and release them, imparting enough kinetic energy to raise the balls through some height h. Clearly, the tubes will slow down as they exhaust their kinetic energy. But what will happen when height h is reached? Will they just stop turning, or will the balls start to roll downwards and force the tubes to rotate in the reverse direction?
[2] The presenter throws out a couple of hints that this phenomenon may be somehow philosophically interesting vis-a-vis time's arrow. Is this the case, or is it a trivial curiosity?
I don't see why they would roll all the way down. Why would ideal tube bearings prevent them from finding a new equilibrium position at a new height? There might be some small oscillation around that new equilibrium tough.
Around 11:06 he explains why the system has no time symmetry. I think this is similar to a one-way-valve or a ratchet, where you can also tell the time direction from kinematics.
Likes Swamp Thing
I am not too sure if my understanding is correct as to why the balls' N-S axis should tilt away from the plane radial to the tube, when the tube is rotated. I am guessing that it is the total inertia of the ball, i.e. a combination of mass and moment of inertia, resisting the action of the wall's surface. Is this true?
If this is true, then there should be no upward drift in the following condition: Start with an initial condition where (a) the balls' magnetic axes are aligned within the radial plane (b) the balls have angular momenta around their respective magnetic axes such that their rolling would exactly cancel the movement of the wall's surface (c) they have no linear velocity (d) the wall is rotating at a uniform angular velocity such that it cancels out the rolling as stated in point (b).
Is the above true? If so, it also means that if we start with the tubes stationary, and apply a very, very small angular acceleration to the tube, then there will be very little deflection of the balls away from their relaxed / radial alignment, hence the vertical rolling will be quite negligible even after the tubes reach a significant angular velocity.
In other words, the vertical velocity that is ultimately achieved would be very much a function of the initial conditions and the history, with a spell of acceleration being required to really kick start the process.
Pheww.. 😅
So... any errors in the above thought process?
I think this is because the friction acts below the effective magnetic force, so you have a torque around the radial axis, which tilts the N-S axis away from the radial plane.
If this is true, then there should be no upward drift in the following condition: Start with an initial condition where (a) the balls' magnetic axes are aligned within the radial plane (b) the balls have angular momenta around their respective magnetic axes such that their rolling would exactly cancel the movement of the wall's surface ...
They would still have rolling resistance, that would shift them from their rest positions and tilt the N-S axis as described above.
Is there a short period, when you reverse the direction of rotation, when the balls change orientation, before they begin to climb again?
I will watch at slow speed and try to see if that happens.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
