Question about brightness temperatur​e
  • Thread starter Thread starter newsim
    Brightness
Brightness temperature can be converted to actual temperature, typically using principles of blackbody radiation. The concept relates to how objects emit infrared radiation based on their temperature. Astronomers often utilize this method to determine the temperature of distant celestial bodies. The discussion highlights the relevance of infrared thermometers in measuring surface temperatures. Understanding the relationship between brightness temperature and actual temperature is essential for accurate thermal measurements.
newsim
It is possible to convert brightness temperature of Earth surface (K) to the actual temperature?
Is there any formulae for such conversion?
Thanks in advance!
I'm not sure "brightness temperature" has any meaning, but you are basically describing an infrared thermometer.
Could this be the sort of thing you are after. Any body that is radiating energy due to its temperature alone will have a spectrum as shown in the diagram.
I think this is used by astronomers to find the temperature of distant sources - optical and 'just warm'.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
