What is the confusion with the Dedekind Cuts example for √2?
  • Thread starter Thread starter mesa
mesa
I don't take issue with the 'cuts' but am having difficulty understanding an example given in my text for √2. After going over the right and left classes the text jumps into,
"Then this section is such that the R-class has no least member and the L-class has no greatest member; for, if 'x' be any positive rational fraction and,
$$y=\frac{x(x^2+6)}{3x^2+2}$$ then $$y-x=\frac{2x(2-x^2)}{3x^2+2}$$ and $$y^2-2=\frac{(x^2-2)^3}{(3x^2+2)^2}$$, so x^2,y^2 and 2 are in order of magnitude"
Given above
A look on wikipedia shows that the last part (where it states, '...are in order of magnitude') seems to represent x^2<y^2<2, other than that I don't understand what the author is getting at or where these equations come from.
***EDITED*** To correct a mistake pointed out by Petek.
There appears to be a typo in your above equation for y^2. Both x and y are supposed to be rational numbers. However, if x=1, then $$y^2= \frac{-1}{25}$$ so y can't even be real.
Likes 1 person
You are correct, I missed a minus 2. Thanks for the correction!
I think the author is asserting in somewhat obscure (Hardyish?) language that either ##x^2 < y^2 < 2## or ##2 < y^2 < x^2##, depending on whether ##x \in L## or ##x \in R##.
To see that this is true, consider the two possibilities:
Case 1: ##x \in L##
Then ##x^2 < 2##, so the formulas for ##y-x## and ##y^2 - 2## imply that ##y-x > 0## and ##y^2 - 2 < 0##.
Case 2: ##x \in R##
Then ##x^2 > 2##, so the formulas imply that ##y-x < 0## and ##y^2 - 2 > 0##.
