Question about Dense sets in R.
  • Thread starter Thread starter cragar
    Sets
cragar
Decide wheter the following sets are dense in ℝ, nowwhere dense in ℝ
, or somewhere in between.
a) A= \mathbb{Q} \bigcap [0,5]
b) B= \{ \frac{1}{n} : n \in \mathbb{N}
d) the cantor set.
a) so we have the rationals intersected with [0,5], so we have all the rationals from
[0,5], which is dense on that interval.
b) this set does not seem like it is dense, except maybe close to zero, but even then
I could find an interval close to zero that did not contain any elements in my set.
d) The cantor set is nowhere dense because it has no intervals, if I have an interval of positive length stating at one of the endpoints of the cantor set it would stick out and it wouldn't contain any points in my set.
Your answer for d is confusing, a set does not need to contain an interval to be dense, for example the rationals
is the second thing I said in part d okay. " if I have an interval of positive length stating at one of the endpoints of the cantor set it would stick out and it wouldn't contain any points in my set."
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
