Exploring Dipoles: Understanding the Charge Separation Phenomenon
  • Thread starter marc32123
  • Tags
    Dipoles
In summary, a dipole is a separation of two equal but opposite charges and cannot have a different amount of charge as it is defined by having equal and opposite charges. The electric field of a charge distribution can be represented in various ways, including a sum of fields due to different charge distributions or a multipole expansion. A dipole with two charges -q and Q separated by a distance d will have a multipole expansion that includes a dipole component.
marc32123
Question about dipoles...
I read somewhere that a dipole is a separation of two equal but opposite charges. Is this true or can the two charges of a dipole have a different amount of charge?
Chemistry news on Phys.org
As I said in your other post, you can describe the field of a charge distribution outside a sphere containing it in terms of a sum of multipole moments. If you have two unequal charges, the most important ones are the monopole (the total charge) and the dipole, although also higher moments, like quadrupole and hexapole moments will be present. However their importance rapidly decreases as the field of a monopole falls off like ##1/r^2##, that of a dipole as ##1/r^3## and that of a quadrupole as ##1/r^4## and so on, so that the higher multipole moments are only of importance for very short distances.
Is this true
yes.
... or can the two charges of a dipole have a different amount of charge?
Short answer: No - by definition a "dipole" has equal and opposite charges.
You seem to be having trouble grokking what is being explained in other threads.
The electric field of a charge distribution can be represented in lots of different ways.
It can be just itself of course.
Because of the superposition principle, it can be a sum of fields due to different charge distributions too:
It can the the sum of the fields due to each charge by itself - this is probably the first one you learned.
It can also be the sum of the fields due to different ways that charges can be separated.
This is called the "multipole expansion". Which you probably have not covered yet.
Or pretty much anything you like - so long as they all add up to the field you need.
Some ways of adding up fields are easier than others - the first two are the easiest.
See lecture:
http://www.pas.rochester.edu/~dmw/phy217/Lectures/Lect_20b.pdf
... it's a bit like how you can construct complicated wave patterns by summing sines and cosines.
Two charges -q and Q separated by a distance d has two poles but it is not a "dipole".
It will have a multipole expansion that includes a dipole component.
You can have a go calculating the expansion if you like.
1. What is a dipole?
A dipole is a molecule or a part of a molecule that has two equally charged ends, one positive and one negative. It is caused by an uneven distribution of electrons within the molecule.
2. How do dipoles affect the properties of a molecule?
Dipoles can affect the polarity, solubility, and reactivity of a molecule. They can also determine the strength of intermolecular forces, such as dipole-dipole interactions or hydrogen bonding.
3. How can dipoles be measured?
Dipoles can be measured using various techniques, such as infrared spectroscopy, nuclear magnetic resonance (NMR), or X-ray crystallography. These methods can determine the magnitude and direction of the dipole moment within a molecule.
4. What is the difference between a permanent dipole and an induced dipole?
A permanent dipole is present in a molecule due to an uneven distribution of charge within the molecule itself. An induced dipole, on the other hand, is created in a molecule when it is placed in an electric field, causing the distribution of electrons to shift temporarily.
5. How does the presence of dipoles affect the behavior of molecules in a solution?
In a solution, dipoles can interact with other molecules through dipole-dipole interactions or hydrogen bonding, affecting the solubility and reactivity of the molecules. They can also affect the boiling and melting points of the solution and its ability to conduct electricity.
  • Chemistry
  • Electromagnetism
  • Electromagnetism
