Question about Electric Potential
To calculate the electric potential at point P due to a charged rod, divide the rod into small segments and treat each as a point charge. Use the formula Kq/r to find the potential from each segment, where q is the charge of the segment and r is the distance from the segment to point P. Integrate this expression over the length of the rod, from the position of point P to the end of the rod. The integration yields the total potential, which can be computed by multiplying the result by the charge density (lambda) and the constant k. This method effectively provides the required electric potential at point P.
scissors
How do I calculate the potential at the point P? Assuming the rod is charged with 8 micro Coloumbs? I'm looking at equations, Kq/r, and I think there is some integrating involved, but I'm stumped. Here is a diagram...any help is greatly appreciated!
| 10 cm....35 cm
P - - - - ====================
Okay, I guess the double line refers to the rod (which is 35 cm long?), and P is 10cm from the end of the rod.
Divide your rod into little segments of length dx. Assume the rod has uniform charge density and write down the charge on this element. Treat each element as a point charge, at distance x from P and write down the potential due to this point charge at P. Now integrate this between the values of x that the rod occupies.
Thanks very much! I was able to get the answer by integrating dr/r from (.10 to .45), and multiplying by lamda (Q/.45) times k.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
