Question about forces due to magnetism
  • Thread starter Thread starter DCN
    Forces Magnetism
The force on a charged particle in a magnetic field is determined by its velocity relative to any inertial reference frame, not just the source of the magnetic field. When the particle is at rest relative to the source, it experiences no magnetic force, only an electric force from the source charge. In a different reference frame where both the particle and source are moving, the magnetic field and forces must be recalculated using Lorentz transformations. The discussion emphasizes that the fields transform when changing frames, which is crucial for accurate calculations of forces. Understanding these transformations is essential for resolving discrepancies between forces calculated in different reference frames.
DCN
The force on a particle moving through a magnetic field is given by:
$$\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
F} = q\,\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} \times \mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
B} $$
Is the velocity ##\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} ## relative to the source of magnetic field or some third party observer?
The velocity is relative to any inertial reference frame. It is not necessarily relative to the source, particularly if the source is moving non inertially.
If that's the case, then please explain this.
Let's say that there is a test charge ##q## whose position from the origin is given by the radial vector ##\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
r} ## and there is a source charge ##Q## at the origin moving to the right along the positive ##x##-axis with a constant velocity ##{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over v} _s}## with respect to ##q##.
Now, in the rest frame of ##q##, ##q## has a velocity of magnitude ##0##, so it will not feel any magnetic effects. The force it will feel will be solely from the electric field generated by ##Q##. The force in the rest frame of ##q## is then:
F} = {{Qq} \over {4\pi {\varepsilon _0}}}{{\hat r} \over {{{\left\| {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
r} } \right\|}^2}}}$$
If we consider a difference reference frame in which we are moving to the right with a velocity of ##{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} _o}##, then ##q## will have a velocity of ## - {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} _o}## and ##Q## will have a velocity of ##{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} _s} - {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} _o}##. The magnetic field then produced by ##Q## is:
B} = {{{\mu _0}Q} \over {4\pi }}{{\left( {{{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} }_s} - {{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} }_o}} \right) \times \hat r} \over {{{\left\| {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
The force on ##q## due to the magnetic field will then be:
F} = - q\,{{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} }_o} \times \mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
B} $$
F} = - {{{\mu _0}Qq} \over {4\pi {{\left\| {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
r} } \right\|}^2}}}\,{{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} }_o} \times \left( {\left( {{{\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
v} }_o}} \right) \times \hat r} \right)$$
So the total force the particle will experience in the moving reference frame is:
$${{Qq} \over {4\pi {\varepsilon _0}}}{{\hat r} \over {{{\left\| {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
r} } \right\|}^2}}} - {{{\mu _0}Qq} \over {4\pi {{\left\| {\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}}\over
Which is clearly not equal to the force found in the stationary reference frame. Am I missing something here?
Yes. The fields have to transform as well when you change frames.
How does that work?
I don't understand the question. There is a Lorentz transformation for electromagnetic fields. You change frames, you need to use it to determine how the fields transform.
