This makes no sense, because “the reference frame of the rod” is the frame in which the rod is at rest. Let’s try describing your setup again:Chenkel said:If there is a rod with proper length (L sub zero) of 10 and it is to go at 10 meters per second along its length then in one second it will travel its length from the reference frame of the rod
We have a rod, and using that frame in which it at rest its length is ten meters; its proper length ##L_0## is ten meters. Of course using this frame it is not moving, but we can say that a bird flying alongside the rod at ten meters per second will take one second to travel the length of the rod.
Or we can use the frame in which the bird at rest. Using this frame the rod is moving past the stationary bird at ten meters per second and its length is ##L_0/\gamma##. At that speed it takes ##1/\gamma## seconds for the length of the rod to pass the bird.
It would be a good (as in will clear things up for you more than anything else) exercise to draw a Minkowski spacetime diagram showing the paths through spacetime of the bird and both ends of the rod.
