Is a nth order ODE considered linear if n=2?
  • Thread starter Thread starter Saladsamurai
    Linearity
Saladsamurai
I am reading through my Diff Eqs Text and I follow most of the lingo. However I am just a tad confused by the statement:
An nth order ODE is said to be linear if F is linear in y,y',...y^(n)
Then it gives the example:
a_n(x)\frac{d^ny}{dx^n}+a_{n-1}(x)..+a_0(x)y=g(x)
It then says: 'On the left-hand side of the above equation the dependent variable y and all of its derivatives, y,y',y'',...y^n are of the first degree.
Clearly I missed something in Calc. If n=2, I have: \frac{d^2y}{dx^2}
Why is this linear if n=2?
Thanks,
Casey
You're confusing the *order* of the derivative with its *degree* in the equation.
y'' + y = 0
is a second-order linear equation. Second-order because the highest order derivative in the equation is a second dervative. Linear because the equation itself is linear in both y'' and y.
In contrast:
(y'')^2 + ay^3 = 0
is a second-order NON-linear D.E. Second-order for the same reason. NON-linear because it is QUADRATIC in y'' and CUBIC in y. I hope this clears things up.
y'' + y = 0
In contrast:
(y'')^2 + ay^3 = 0
I think it does. y' just means "the 1st derivative" and similarly for y" however if either one y' or y" or y for that matter were raised to any power above 1, the DE would no longer be linear.
Thanks!
Yes, that is correct. Also note that other "non-linear" functions of the dependent variable, y or its derivatives, such as sin(y) or exp(y"), would make the equation non-linear.
Great, thanks Halls and cepheid. Hey also, I know that the right-hand side can be equal to 0 or a function of the independent variable; what about a constant?
Like \frac{d^2y}{dx^2}-\frac{dy}{dx}+6y=7 ?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
